Amp swing
Old Jul 10, 2011 | 04:00 AM
Greasepunk's Avatar
Question Amp swing
At idle my battery volt meter swings +/- about 2 steady. Tensioner pulley is new, belt looks fine and not squeeling, not sure what problem is. I have had an instance where I went WOT and car seemed to lose electrical power and mechanical for about a second, but that was just once. The voltage swing is everytime I start the car and remains wether car is cold or hot, volts are steady while driving/under load. Do I need a new part or maybe have an underdrive pulley installed already? I'm not 100% on what mods are installed on it.
PS. I apologize for the multiple postings, I've asked these questions on other forums as well with minimal feedback.
Old Jul 10, 2011 | 09:04 AM
Marc 85Z28's Avatar
Re: Amp swing
Do you have a 40 year old Ford? Because the car in your sig never came with an ammeter.
Old Jul 10, 2011 | 09:47 AM
Greasepunk's Avatar
Re: Amp swing
volts then
Old Jul 10, 2011 | 03:16 PM
rv93's Avatar
Re: Amp swing
are you 100% sure the belt is fine? any leaks? it sounds like you have some sort of leak on your belt, or the belt is just worn out, and its slipping sometimes
Old Jul 17, 2011 | 10:27 PM
oldmano2z's Avatar
Re: Amp swing
over rev can fry the diodes in a stock alternater. mine jumped like that and i replaced it with a 145 amp truck alt. cured.. bolts right in i think its number is like 442 delco parts guy can tell you..
RUENUF
Mar 13, 2016 03:37 PM
HibachiZ28
Nov 6, 2015 12:53 AM
cmsmith
Sep 14, 2015 09:25 PM
secbase8
Parts Wanted
Sep 8, 2015 07:11 PM
Boss002
Jul 9, 2015 03:33 PM
