help
Old Feb 14, 2011 | 10:09 AM
silverz28ls1's Avatar
help
i have just recently bought a 1999 z28 ls1. i love the car but it has some bugs that need to be worked out. for starters when i go into reverse my reverse lights do not come on. secondly all my lights surge from bright to dim. also i have a lil back fire when i let off the gas and tap it again i have a crane cams tuner....
mods are cat back greddy intake? and k&n intake,
Old Feb 14, 2011 | 10:10 AM
Re: help
Old Feb 14, 2011 | 09:39 PM
raulz28's Avatar
From: 5 minutes from the warzone in mexico(south texas)
Re: help
Nice car and welcome to the forum. Does the car have the check engine light one?
Old Feb 14, 2011 | 09:44 PM
Re: help
no check engine light.... the back fire is more of a gurgle
Old Feb 14, 2011 | 09:54 PM
raulz28's Avatar
Re: help
Do you have cats? As for the reverse lights it might just be the bulbs so try that, if not then it could be the backup light switch
Old Feb 14, 2011 | 10:18 PM
Re: help
yea i still have the cats
video of surging not the best and a exhaust rev
Old Feb 14, 2011 | 11:26 PM
'91 1LE's Avatar
Re: help
The lights surging is your alternator on its way out. It has some bad diodes and is not putting out the amperage it should.
Old Feb 15, 2011 | 10:35 AM
WhiteHawk's Avatar
Re: help
Did you check the bulbs in your backup lamps? Sounds stupid but you never know. I would pull out that tuner tune, too. That could be causing issues.
-Geoff
Old Feb 15, 2011 | 10:47 AM
Re: help
yea im going back to stock tune also i need a new rack and pinion they have 2 diffrent ones which one should i buy. the one with firm handling suspension or with out the firm handling and suspension
