Need some help with my 2000 Z28 running bad.
Old Aug 14, 2011 | 07:20 PM
RickWalton's Avatar
When driving normal the car runs fine, but when I run it hard, it hesitates, sputters, and acts like it wants to back fire. Over the last couple of months, I've cleaned the injectors (lots of carbon) didn't help, replaced the pre-converter O2 senors didn't help, and cut off the cad converters. Still runs like crap when pushed. Any ideas what to check next?
Old Aug 14, 2011 | 08:37 PM
rv93's Avatar
Re: Need some help with my 2000 Z28 running bad.
does it throw any codes? that would be a good place to start. if not, it could be a bad maf, tps, coolant temp sensor, or most things in the engine, really
Old Aug 15, 2011 | 01:23 PM
rod442's Avatar
could also be a plugged fuel filter or a pump going bad.
maybe get a fuel pressure guage on it. Try new plugs?
Also clean the maf, or better yet; see if you can swap with a know good one.
Old Aug 30, 2011 | 09:10 AM
bwarren337's Avatar
try checking the pluga and wires also check for any type of leaks such as: exhaust, vacuum, ect..
Old Sep 1, 2011 | 03:22 AM
L.dookie's Avatar
definitely check for small vacuum leaks or exhaust leaks. an exhaust leak before the 02 sensors will cause a false lean making the car run rich.
Old Dec 16, 2011 | 01:10 PM
RickWalton's Avatar
First off, thank you for the replies. Update:The SES comes and goes. Usually when it is on, it's O2 sensors. My guess would be where I cut off the converters. Leaks and plugs are next. It's an automatic, so most bog downs occur before and/or after a shift. I heard the plugs are a pain. The 8th almost impossible to get to. Any suggestions? The SES just came back on. Took it out today, floored it, and couldn't break 40 MPH. Passing gear will engage, but the car doesn't go.
Old Dec 24, 2011 | 08:40 AM
AL SS590 M6's Avatar
Moderator
Did you check the fuel system? As Rod 442 stated a plugged filter or bad pump could cause your symptoms.
LastChance719
Cars Wanted
Feb 16, 2015 11:03 AM
Jazsun
Dec 29, 2014 12:14 PM
Hurin
Dec 13, 2014 07:38 PM
Mad_Ice
Jul 29, 2002 09:44 PM
