L92 with f.a.s.t system need some help! Or some direction!! Thanks!
I have an L92 I will be running twin turbo set up, but one problem... I purchased a f.a.s.t. System part number 30-113010, I pretty much just got a ecu n harness n that's it! I believe its a bank to bank system, what do I need to do to make it work with coil packs? I've done searches and only came up with one in the archives but still was blurry on what they did. I'm also looking for some type of schematic for the harness. Thanks guys hope someone can help me out, anxious to get this thing going!
Is it possible to make this work? Hope so
Re: L92 with f.a.s.t system need some help! Or some direction!! Thanks!
Where are you located? If you are on the east coast, I can point you to a shop that can work miracles with the FAST system (and most others).
carguyshu
Jan 22, 2017 11:19 AM
