Oil pump question
Old Jul 14, 2011 | 08:03 PM
cummins2005's Avatar
Exclamation Oil pump question
I have a 01 z28 and the oil pressure isn't the greatest going down the road so I parked it. I went through it a couple months ago and all the seals and bearings look good. Could this be the oil pump? And also is this very hard to change? A website with instructions and pictures would be awesome. I guess I could buy a manual but anything will help!!!
Old Jul 17, 2011 | 10:32 PM
oldmano2z's Avatar
Re: Oil pump question
did you check the oil sending unit at the back of the block? they give faulty readings sometimes a good auto repair guy can hook up a gauge to check oil pressure and to see if sensor is bad. just sayin..
Old Jul 18, 2011 | 08:53 AM
Marc 85Z28's Avatar
"Isn't the greatest"? Can you elaborate on that?
Old Aug 2, 2011 | 11:32 AM
Hank'sZ28's Avatar
cummins2005,
Although it would be splendid if you did stipulate an approximate oil pressure reading, I am happy to oblige your request by posting up a concise write-up of the procedure for replacing the oil pump. Please note that this is a very basic guide so I may be missing a few minor details here and there!
**For reference: LS1 Oil Pump diagram
1. Drain the crankcase.
2. Remove or disconnect the following:
Front cover
Oil pan
Oil pump screen
Oil pan deflector
Oil pump and propeller shaft
--Install or connect the following--
Oil pump and propeller shaft. Torque the bolts to 18 ft. lbs. (25 Nm).
Oil pan deflector. Torque the nuts to 18 ft. lbs. (25 Nm).
Oil pump screen. Torque the bolt to 106 inch lbs. (12 Nm).
Oil pan
Front cover. Torque the bolts to 18 ft. lbs. (25 Nm).
3. Refill the crankcase.
It really is that straight-forward of a job. If you need further elaboration then do not hesitate to ask
Old Aug 2, 2011 | 02:55 PM
Marc 85Z28's Avatar
Front cover
Oil pan
Oil pump screen
Oil pan deflector
Welcome to the site.
The oil pan does not need to be removed. What is the oil pump propeller shaft? What you've outlined isn't very straight-forward. A much better description of what needs to be done can be found at http://www.ls1howto.com/index.php?article=4 Regardless, who says the oil pump has failed? Oil pressure problems can be caused by multiple different failures, which is why we need more info from the OP.
Old Aug 2, 2011 | 05:06 PM
johnny6's Avatar
Parameters would be a good start.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
