rod bolts question
Old Mar 3, 2011 | 11:57 AM
cory123456's Avatar
rod bolts question
i was just wondering whats the safest max rpm for the stock rod bolts in ls1, becuase im planning on running a cam that peaks at 6400. any info would be great thanks.
Old Mar 3, 2011 | 01:04 PM
Chrome383Z's Avatar
Re: rod bolts question
With a 99 your probably going to want to limit it at 6,500rpm I wouldn't push it much more then that... later years you can probably get away with 6,800rpm.
There are people that push them to 7k, but IMO it's only a matter of time that you grenade it doing that.
Upgrade your rod bolts then you can feel safer.
I have my limiter at 6,500 now and shift at 6,200. But I'm only running a G5x2 so sounds like you have a little more cam.
Old Mar 3, 2011 | 01:28 PM
cory123456's Avatar
ya im gunna be running the torquer v3 cam so ill have the limiter set to 6500 and it should be okay untill i decide to do rod bolts thanks for response.
ChrisFrez
Jan 11, 2015 03:47 PM
Catmaigne
Dec 25, 2014 12:16 PM
Hurin
Dec 13, 2014 07:38 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
