heads
Old Sep 24, 2011 | 11:33 AM
JFH's Avatar
JFH
heads
I just bought a set of mti stage 2 ported ls6 heads ,does anyone know any thing about these heads? Any information would help. I am trying to find out about them so I can find a camshaft that wil work with this application.
Thanks for your help
Frankie
Old Sep 26, 2011 | 08:46 AM
Antz97ZNJ's Avatar
Re: heads
http://www.mtiracing.com/
Old Sep 26, 2011 | 04:12 PM
Marc 85Z28's Avatar
Re: heads
Originally Posted by Antz97ZNJ
That is the "other" MTI. There is another MTI, now defunct, that was big on porting stock LS1 castings, and that's probably what he has.
Old Sep 28, 2011 | 05:06 PM
JFH's Avatar
JFH
Re: heads
Thanks, do you know where I can look to try and find out the flow? They are hand ported and opened up very nice. The guy that had them is a tuner in VB and he had them on a 99 vette. He claims 440 hp at the wheels with a small cam is what it made does that sound right? I think he said a 220 duration with like a 530 or 540 lift.
Thanx again
Frankie
Old Sep 29, 2011 | 10:25 AM
Marc 85Z28's Avatar
Re: heads
If they're the 2e heads that I believe they are, they advertised 315cfm intake @ .600" lift with a 4" bore. On the LS1 3.89" bore, only 307cfm.
Back in 2004? when I was researching heads for my build, our local flow bench had a set and they did around 290 intake and 195 exhaust at .600", with less than stellar mid-lift flow. For over $2200, it wasn't worth it. The new 220cc PRC heads had better numbers and were half the price, and that's what I ended up with.
Those power numbers seem a little high for a 220 duration cam, but without knowing the rest of the combo anything is possible. I would expect to see 410rwhp or so with an LS6 intake and headers/good exhaust through a manual trans.
Old Oct 12, 2011 | 06:26 AM
JFH's Avatar
JFH
Re: heads
Thank you so much for your help!!!!
Frankie
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
