Clunking noise from rear end.
Just bought an 02 z28 and noticed a clunking noise from the rear end area of the car while going over bumps. I was told by the mechanics at the place I bought it from that it was the shocks. I replaced the shocks (which appeared to be loose) and the noise is still there. Any advise would be appreciative!
Re: Clunking noise from rear end.
check your exhaust loop for wear just above the rear end, I found my exhaust had gotten loose at the y pipe and it was off by about half an inch a the loop causing it to bang over "hardish bumps" I just r2 the u clamps and moved it fwd... no more noise!
I would bet it was the exhaust as well, I've owned 3 f-bodies and exhaust clunks are common, if someone ran over a curb, which I have done twice myself, then the exhaust could be bent,
I figured it out, it was a combination of the rear lower control arm bushings and the right rear exhaust mount bushing. Replaced those and the noise is gone. Thanks everyone for the advice.
squarehead
Nov 21, 2014 08:02 PM
