Why would my ASR turn off?
Old Mar 29, 2011 | 07:44 PM
DanM458's Avatar
On my 02 Z28, within a minute after starting my car, the ASR shuts off and my ABS INOP light also comes on. Does anyone know what would make this happen?
Old Mar 29, 2011 | 09:34 PM
AL SS590 M6's Avatar
Moderator
Re: Why would my ASR turn off?
Probably one of the ABS sensors is shot. Check the ABS and traction control fuses.
Old Mar 31, 2011 | 01:41 AM
Z28silverstreak's Avatar
My '96 Z28 did that awhile ago when I turned the hazards on. Doubt this will help you at all, but I ended up tracing it to the turn signal flasher! Since I replaced it it's never done it since.
Old Mar 31, 2011 | 08:35 AM
Chrome383Z's Avatar
I'm guessing a wheel speed sensor.
Old Apr 3, 2011 | 09:46 PM
Mike 92LX's Avatar
Get a brake scanner. Bet its one of the rear abs sensors
Old Apr 10, 2011 | 04:33 PM
You may also have a problem with the brake lights, which turns on the ABS INOP light, which in turn turns off the ADR, because there is a problem with the brakes.
Old Apr 10, 2011 | 07:34 PM
rod442's Avatar
thinking the brake light bulbs (or wiring to them) have nothing to do with VSS, ABS, or TCS. or any function in the braking system for that matter.
otherwise the car could have no/poor brakes if the bulbs went out. NO way they would design them that way.
Old Apr 26, 2011 | 11:04 PM
DanM458's Avatar
thanks guys, it ended up being a wire from the sensor that just broke
dluna333
15
Mar 13, 2015 12:30 PM
edman
Jan 25, 2015 02:41 PM
1996LT1Z28
Jan 14, 2015 08:09 AM
formula79
26
Aug 5, 2002 12:21 PM
z28chrizz
Oct 15, 2001 06:46 PM
