Oil Pressure problems, I got the solution
Old May 11, 2011 | 04:43 PM
OutlawPerforman's Avatar
Thumbs up Oil Pressure problems, I got the solution
I have seen many posts discuss oil pressure problems as far as the readings being off and dropping low. Also the gauge going up and sticking there.
Well I found out a solution, hopefully all us ARE RUNNING A FULL SYNTHETIC
We need to use a K&N oil filter
I had really low pressure when I bought the car and the reading would go up to about 50 and stick there, my buddy told me to use a k&n or royal purple oil filter and this fixed the problem I get 40 at idle and 60+ when my foot is in it.
hope this helps you guys
Old May 11, 2011 | 06:17 PM
johnny6's Avatar
Re: Oil Pressure problems, I got the solution
What was your oil pressure before? K&N is ok, Mobil1, AC delco, Napa gold are cheaper and better. Also, a sticking oil pressure gauge is either a sending unit problem or the actual gauge itself.
Old May 12, 2011 | 12:15 PM
Marc 85Z28's Avatar
Oil pressure problems are RARELY solved with a simple oil and filter change.
We do NOT need a K&N filter.
Old May 12, 2011 | 04:32 PM
when I first got the car the oil pressure would drop down really low to around 20 and under it gave me a scare so I changed it.
It was horrible coming out and low so maybe the guy didn't care for her good before me and could be just a coincidence and that my oil pressure got a ton better
(from 40 to 60+).
But If your running synthetic than you do need a synthetic filter doesn't need to be k&n was just a suggestion.
Old May 12, 2011 | 05:09 PM
Slappy3243's Avatar
How many miles on your car? If the oil came out looking horrible and it was low, and you had low oil pressure, I would be kind of worried that the guy before me didn't change the oil much.
Old May 12, 2011 | 06:35 PM
Marc 85Z28's Avatar
I have to ask... Are you attempting to promote or sell some product here, or are you just very naive?
Old May 12, 2011 | 07:33 PM
How am naive Ive been building motors all my life, this is my first Ls1 so I just wanted to dicuss it. dont gotta hate on me,
Im not trying to sell anything. I was jus suprissed a oil filter made a big difference
Also yes I was concerned about the previous owner but we only had it for a month (was only 16 and his dad said he couldnt have it), so I got in contact with the one before and explained he cared for it good
Old May 13, 2011 | 07:23 AM
Kraest's Avatar
Retired
LS1s don't have oil pressure problems.
Old May 13, 2011 | 09:29 AM
Marc 85Z28's Avatar
If that's true, then you should know that oil pressure problems, specifically like what you've described, are not solved with an oil change.
Old May 14, 2011 | 12:02 PM
This is true thats why I posted I couldnt figure out why it got so much better, wanted some opinions. plain and simple
Old May 14, 2011 | 12:09 PM
If the previous owner was runner a regular oil and I put a full synthetic then YES the oil pressure would go up. That is probably what was going on, maybe had nothing to do with a different filter. Anyways thanks for the feedback
Old May 14, 2011 | 01:09 PM
GreenDemon's Avatar
I've always used Mobil 1- mostly because as a synthetic it's not really that expensive if you get it in the 5 qt containers at walmart.
I refuse to buy an overpriced K&N filter; have always used Purolator or Delco w/ zero problems.
Most of the time changing the oil is far more important than the particular brand. All of the lubrication repairs I've done at work have been because people just don't maintain their cars. Doesn't matter what oil you're using if your oil pickup is clogged with carbon.
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
