Optimum pre-load for LS7 lifters ?
Old Feb 10, 2011 | 03:23 AM
bluz28's Avatar
Question Optimum pre-load for LS7 lifters ?
What's the optimum pre-load/ pre-load range to use?
Thanks!
Old Feb 10, 2011 | 12:32 PM
Marc 85Z28's Avatar
Re: Optimum pre-load for LS7 lifters ?
I set mine at .080" back in 2007 when I built my engine. Spins clean to the 7200rpm limiter with no abnormal/sewing machine noise. Nobody knew what was optimal then, and now it varies depending upon who you ask. I've heard as little as .050" and as much as .120"
Old Feb 10, 2011 | 01:24 PM
bluz28's Avatar
So do you think .0411" preload would be fine(quiet), my wipe pattern looks centered and about 1.5mm wide(1/16") with the 1mm shims supplied with my YT 6645 rockers, btw preload is 7/8 turn with factory bolts torqued to 22ft.lbs.?
Old Feb 11, 2011 | 08:05 AM
Marc 85Z28's Avatar
~.040" is not enough - it will be noisy. IMO you want at least .060" GM sets them to between .080" and .100"
Why are you using Yella Terras? Unless you're running an altered valve angle and set up the entire valvetrain PERFECTLY, they're going to cause valve control problems.
Old Feb 11, 2011 | 11:48 AM
bluz28's Avatar
Thanks, I was starting to get the feeling that my pre-load was on the low end so I just ordered some 7.450" pushrods, that should put me up to .066" pre-load. I've so far heard anywhere from .03-.08", .05-.08", and that .04" would be good, and a couple .08-.100", so it's been very frustrating trying to get a good understanding on the best preload range
BTW, I just installed AFR 205 w/66cc chambers w/PAC 1521 springs, and gm mls head gaskets. The cam also has LSL lobes (227/231 111 lsa+2).
The YT's I bought several yrs ago, and had never got around to installing them before. I guess if I have any issues with them I'll remove them(hopefully not).
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Aug 24, 2015 06:41 AM
mrwz28
Jul 8, 2015 09:11 PM
