heads for cam
Old Feb 22, 2011 | 09:48 PM
bwarren337's Avatar
heads for cam
I dont know much about heads but i will be putting a ms4 cam in my ls1 and was wondering if i needed to do heads or are stock ones ok....if i need to replace heads does anyone have suggestions on which heads to get for the ms4 cam...thanks
Old Feb 22, 2011 | 10:43 PM
henryz28's Avatar
Re: heads for cam
Heads are not a must; but ported or aftermarket heads would provide more hp. I would defiantly be sure to have at-least an ls6 intake and depending on what injectors you have I would think about swapping the injectors. A mail order or dyno tune should be done also.
Old Feb 23, 2011 | 09:45 AM
bwarren337's Avatar
Re: heads for cam
I have a ls6 manifold on already..what injectors would you recomend getting to suport the ms4?
Old Feb 23, 2011 | 06:24 PM
henryz28's Avatar
Re: heads for cam
What year is your car? I know some years came with the ls6 intake; If you have one of those then you more than likely will have larger injectors too and you'll be OK, but if you added the ls6 intake I would go with a 30lb ford svo or a 36lb if you plan on further mods down the road. 30lb would be fine if you don't plan on doing more mods later, but if your going with new injectors I would do 36lb;they will work fine now and provide more fuel later.
Old Feb 24, 2011 | 12:56 AM
bwarren337's Avatar
Re: heads for cam
The car is a 1999. I put the ls6 manifold on there.. do you know of any good sites to get 30lbs or 36lbs injectors from...
Old Feb 24, 2011 | 07:39 AM
Chrome383Z's Avatar
Re: heads for cam
thunder racing, speed inc, texas speed all good places.
Heads I would either go with AI 243s, or AFR 215. I wouldn't mess with any of the others, Trick Flows require (debatable) aftermarket rocker arms so I'm not a fan of them. Thunder sells a shim kit to use stock, but TEA still claims it's not a great idea and the guides will still wear faster then normal.
I tend to favor either of those heads (AI for budget, AFR for $$$)
StansZ28
Feb 19, 2015 07:39 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
