flat spot.....bog....need some help
Old Jun 2, 2011 | 08:23 PM
2011tundra's Avatar
ok here is the deal.....2000 ss ,m6,80000 miles. all new delco parts,plugs, wires, fuel filter. 60 psi at rail, no codes, i unpluged tps and ran multimeter on it and its good! ran the car with maf unplugged and it runs awesome! any ideas here? the car falls hard on its face....
Old Jun 3, 2011 | 06:28 AM
AL SS590 M6's Avatar
Moderator
Re: flat spot.....bog....need some help
Did you clean the MAF?
Old Jun 3, 2011 | 07:37 AM
RevXtreme1's Avatar
MAF has failed. Get a new one (or verified good used one) and swap it out and you will be back to normal. Your staying in closed loop so it will run fine but your running on the default rich side so your fuel economy will suk.
Old Jun 3, 2011 | 08:47 PM
2011tundra's Avatar
yes the maf is cleaned...what are your thoughts on an slp maf? or should i get a delco? i did a search on them and it seems either slp or gm only? thanks for your help!
Old Jun 4, 2011 | 09:21 AM
johnny6's Avatar
Don't waste your money on an SLP MAF.
Old Jun 5, 2011 | 03:18 PM
2011tundra's Avatar
ok.....delco maf on the way! thanks for the help, hope this fixes it!
Old Jun 7, 2011 | 08:04 PM
2011tundra's Avatar
thanks ! car is back to life! the new gm maf is all plastic.....doesnt look anything like the old one,but works perfect!
Quickss96
Jan 29, 2016 05:56 PM
HibachiZ28
Nov 6, 2015 12:53 AM
Str8hp
Parts Wanted
Aug 25, 2015 06:03 PM
Aug 5, 2015 08:35 AM
detroitmuscle
Jul 31, 2015 04:21 AM
