2002 Z28 exhaust
Old Apr 3, 2011 | 09:53 PM
Timmy_Jones's Avatar
2002 Z28 exhaust
A few simple questions for my 2002 Z28.
I am looking for some cheap exhaust work. I am under the impression that the stock manifolds on a 2002 are better than past years and flow similarly to a shorty header, is this accurate? Also, with an aftermarket catback, is an ORY for the stock manifolds worth it? Local guy has a Bassani ORY for stock manifolds for sale...
Old Apr 3, 2011 | 10:25 PM
Kraest's Avatar
Retired
Re: 2002 Z28 exhaust
I'd throw the entire power-robbing stock manifold/Y-pipe in the garbage and go with a True Duals setup with an X-Pipe and Longtubes to free up the power in the LS1 -- You wouldn't believe the difference...
I think Texas Speed (one of our vendors) sells all of the above --
$369 For Longtubes:
http://texas-speed.com/shop/item.asp...d=184&catid=45
$459 For the True Dual Setup:
http://texas-speed.com/shop/item.asp...d=196&catid=56
Those will add around 40-50 horsepower.
Old Apr 3, 2011 | 10:46 PM
Trying to stay away from longtubes for 2 reasons. Shops around here are crazy when inspecting for emission crap (egr/AIR) and the ground clearance is crap on our roads. I have been down the longtube road and wanna try something different.
(I live in Maine - ala Frost Heave Heaven!)
Old Apr 3, 2011 | 11:06 PM
rv93's Avatar
im actually curious about this too. i also have an 02 Z28, and i was looking at texas speed true duals, with longtubes. emissions arent a problem, since i live in indiana (one good thing about this state), and i can sacrifice a bit of ground clearance i guess, but its a daily driver, so id like to keep as much as possible. are my expectations unrealistic? or is this doable?
Old Apr 4, 2011 | 07:09 AM
Kraest's Avatar
Retired
Ground clearance is fantastic with those headers/exhaust setup. I ran it with an Eibach 1" lowering kit with absolutely no clearance issues whatsoever.
Old Apr 4, 2011 | 08:12 AM
rv93's Avatar
alright, thanks. ill definitely look into getting that soon.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jan 5, 2015 07:14 PM
ANDYZ28
Dec 29, 2014 09:13 PM
