Seaform Treatment Good or Bad? e3 plugs?
Old May 12, 2011 | 04:28 PM
OutlawPerforman's Avatar
Im new to this site and love it. I am seeing allot about "seaform" treatment and I am wondering what this is and if its good or bad because I have heard both ways. Also has anyone tried using e3 spark plugs on ur Ls1's if so what were the results
Old May 12, 2011 | 04:31 PM
94QuasarZ's Avatar
Re: Seaform Treatment Good or Bad? e3 plugs?
First off, I would like to say welcome to the forum. I have an LT1 but I've used seafoam a couple of times and my car has responded very well to it, idled stronger, ran smoother. My buddy used it on his LS1 SS and it worked fine for him, I say give it a shot.
Old May 12, 2011 | 07:36 PM
Thanks bro I appreciate it, im not real clear what it is exactly, Ive seen it on a quart of oil is that what it? I really have no idea brother
Old May 12, 2011 | 07:50 PM
johnny6's Avatar
Seafoam comes in a white container, it's a clear liquid that can be used in the fuel system, crankcase and intake. The most popular is the intake, i've been using it for a few years and i'm happy with the results. There's plenty of videos on youtube if you want to see how it's used, be prepared for a smoke show The only sparkplugs we all recommend using are the NGK TR55, never heard of an e3 plug.
Old May 14, 2011 | 01:18 PM
GreenDemon's Avatar
Seafoam thread:
https://www.camaroz28.com/forums/sho...d.php?t=795248
As far as plugs go, the NGK TR55 work well, but for a car that's going to get some miles I'd recommend the Delco Iridium plugs. I used to run the NGKs but now use the Delcos, the NGKs just don't last long enough to deal with the hassle of doing plugs on an LS1 IMO.
Old May 14, 2011 | 10:31 PM
Thanks for Info, after reading the sea-foam posts I think ill stay away from it. It may work but it seems a high risk.
Also on the plugs too. This is my first Ls1 im used to old school 350's and 454's where the plugs are so easy. This one is a challenge and def wanna get the longer lasting ones.
Old May 14, 2011 | 11:59 PM
johnny6's Avatar
There's no risk in using seafoam if you do it correctly.
Old May 16, 2011 | 09:54 AM
Marc 85Z28's Avatar
Originally Posted by OutlawPerforman
Thanks This is my first Ls1 im used to old school 350's and 454's where the plugs are so easy.
If you're familiar with the older SBC and BBC, you've dealt with carbs before. Using Seafoam in the intake will do the same thing pouring a cup of water into the carb (while running of course) will do.
If you can do plugs on a BB, the LS1 should be easy.
Old May 17, 2011 | 07:07 PM
AL SS590 M6's Avatar
Moderator
Ditto
Old May 19, 2011 | 09:10 PM
midnitefx's Avatar
what he said, ive used it on both f-bodys and every car in between and has given great results. Read the instructions and follow them and you will be fine
F'n1996Z28SS
Aug 23, 2023 11:19 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Amshnock
14
Jan 18, 2015 11:47 AM
