1998 Camaro Z28 slow coolant leak
I now own a 1998 Z28 with nearly 200,000 miles on it. Everything checked out when I purchased it, but now the car is leaving a small puddle under the right front tire. It seems like an odd place for a radiator or water pump leak, but I'm about 90% certain it's coolant.
Any suggestions?
Any suggestions?
Re: 1998 Camaro Z28 slow coolant leak
Leaks can travel quite a distance before finally dripping somewhere, you have a few options here:
-Start the car, drive it around until it's fully warmed up and drive it up on ramps. Start by looking in the engine bay for leaks then crawl under the car and investigate.
-Start the car and watch it warm up and look for leaks.
Thanks to johnny6 and JeeperSC (my other car is a 1998 Jeep Wrangler). I crawled under the front of the 1998 Z28 while it was running, after it had warmed up completely, but I could not see anything leaking. It's only after it sits for a while that the puddle appears.
There are a bunch of things that could leak there. The two most likely are the heater hose connections coming off the water pump. After that, the overflow jug is right in front of the wheel well. Also check the small hose connections right by the fill cap.
Wait until it makes a puddle, then run your hand over all the hose connections I listed above. The wet one is the one that is leaking.
-Geoff
-Geoff
NewsBot
Dec 28, 2014 06:20 PM
hotrodyou1
Dec 20, 2014 10:05 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
grendal
Apr 15, 2010 05:20 PM
2000silverz28
Jul 20, 2002 06:14 AM
