1998 Camaro Z28 with Oil Pressure Issues?
Old Jul 13, 2011 | 10:13 PM
MetalHeavy's Avatar
Listen guys I have had my 1998 Z28 in my garage sitting due to a oil pressure reading of zero. So today I fire it up for the first time in a long time and the pressure reads zero. After I shut the car off the gauge raises to normal levels with the are and electronic system being off. I replaced the sending unit and it changed nothing. About a month before the car was placed in the garage on a stand still due to the reading being zero I had problems with acceleration. I was driving it and it had seemed to bog down at weird times. I would drive it and try to step on it and it would almost conk the engine out. But I was able to restart it and get it back home. This was RIGHT before it had the oil pressure gauge drop to zero. I am wondering if it is the gauge itself or actually the oil pump. Seeing as when I had shut it off after the initial start and the gauge would rise to normal specs. Is it the gauge or the oil pump?
Old Jul 13, 2011 | 10:38 PM
MetalHeavy's Avatar
Re: 1998 Camaro Z28 with Oil Pressure Issues?
dude even more weird. I just started it and now all the gauges are fine and everything seems good. Is this a gauge issue?
Old Jul 13, 2011 | 11:50 PM
rod442's Avatar
My .02.
sounds like electrical/guage related. a mechanical pump isn't going to work intermittently.
Plus if it was driven with 0 showing on the guage (and it was accurate); the bottom end would be toast (if you ran it much that way.)
get a mechanical guage on it, before it is toast. someone else can chime in as to what to remove so you can hook one up.
Old Jul 14, 2011 | 11:07 AM
MetalHeavy's Avatar
Actually it was never driven once the gauge had dropped to 0. I replaced the sending unit because I though possibly that could be it and it turns out it wasn't. But after I initially had parked it after I was driving it and it bogged down on me and actually had stalled a few times it sat for a bit. Then I went out and started it one day and the gauge read 0. Only after that did i start it briefly a few times to check to see if the gauge was reading. The battery remained dead as well as the car for about 2 years. Until yesterday when I fully charged the battery and started it real quick and the gauge was fine. So I guess the big question is where do I even start to diagnose the issue? Also what tools and where can I acquire them to diagnose the issue.
Old Jul 14, 2011 | 02:09 PM
BC2002SS's Avatar
a multimeter or go with power probe 3 master kit
http://www.freeautomechanic.com/wiringproblems%206.html
hotrodyou1
Dec 20, 2014 10:05 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
jayblev95
Dec 1, 2014 06:55 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
