camaro LS1 stock fuel pressure ??
i tried the search but nobody has a simple question on their and im tryin to know all the facts of my car but having trouble looking for this one,,,
my 2000 z28 a-4 shows 49psi on ignition on
and 59psi while the car is on
is this normal ????
is this normal ????
Re: camaro LS1 stock fuel pressure ??
Sounds about right. stock running pressure is 60. mine will prime the system to the stock setting when the key is first turned to the "run" position, and then drop a bit untill the car is started. Once running, its back up. If that makes sense.
or in other words, it doesn't hold the pump on, primed, pressure when the car isn't running. it cycles the pump to raise the pressure in the rail for a few seconds just as you turn the key on. If the car doesn't run, it kills voltage to the pump. All normal.
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
