low oil light
Old Feb 11, 2012 | 05:31 PM
hot936spd's Avatar
low oil light
low oil light is on in my 98 ls1, but has plenty of oil, checked, it before i started and after, just came on , wasnt on the previous day. engine is brand new as well, any reason why, anything to be concered about
Old Feb 12, 2012 | 08:45 AM
Dave89IROC's Avatar
If is fill of oil, then it is likely a bad level switch, its in the oil pan, it could of course be wiring, etc., but most likely the switch
Sent from my PC36100 using Tapatalk
Old Mar 2, 2012 | 09:32 PM
OutlawPerforman's Avatar
Re: low oil light
I had this exact problem, and it was suggested to me to change my oil filter to a K&N, I didnt believe it would work but I was desperate to fix it so I changed the oil and put the k&n and it fixed the problem.
This may just have been luck for me or something else, just thought I would share and hope it works for you brother
Old Apr 10, 2012 | 06:45 AM
AL SS590 M6's Avatar
Moderator
Re: low oil light
The low oil level light is driven by a sensor in the right side of the pan and has nothing to do with the oil fiter. More likely that removing the oil and filling it back up corrected the minor fault with the sensor.
Old Aug 19, 2012 | 01:26 PM
BrandonM's Avatar
Re: low oil light
Go underneath the car and take a look at this sensor, My 02 B4C has the same problem and the reason is the wire to the sensor hardened and snapped off
so I'm letting it be since I check my oil ever 2 or 3 days (oil pan gasket leak) and I plan on swapping my ls1 out, so I'll just wait until then to fix it
transam_388
Mar 15, 2015 11:53 AM
Jan 23, 2015 01:13 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
