Doing headers, Which o2 sensors and which plugs
Old Jan 16, 2011 | 09:36 PM
Jachin99's Avatar
Im in the middle of a header install, but the stock setup had 4 o2 sensors, and now i only have holes for 2 with my offroad y pipe. which O2 sensors do i use and which harness do i plug them into, the fronts or the rear harness. thanx
Old Jan 16, 2011 | 11:24 PM
raulz28's Avatar
From: 5 minutes from the warzone in mexico(south texas)
Re: Doing headers, Which o2 sensors and which plugs
I believe you have to connect them to the front ones because those are the ones that measure your A/F ratio and give feedback to the PCM if it is running lean or rich. The rear 02s are for emissions purposes only. As for which ones to use I would just go with the original.
Old Jan 17, 2011 | 06:36 AM
AL SS590 M6's Avatar
Moderator
Yep use any 2 sendors that suit you and hook them to the front harness points. You'll need wiring extensions to do this and your check engine light will be on due to the rear ones not working.
Old Jan 17, 2011 | 01:31 PM
Jachin99's Avatar
Ok good, because i guessed and used the front plugs. Thanx
Old Jan 17, 2011 | 02:43 PM
WhiteHawk's Avatar
If you aren't getting a tune, just have another set of bungs welded on and then plug all 4 sensors in.
-Geoff
Old Apr 18, 2011 | 02:59 AM
anthony.fatica's Avatar
This is an old thread but if you havnt fixed your rear O2 sensor problem I will sell you my simulators. I never even used them because I got mine tuned out a week after I bought them...
Mar 18, 2015 06:31 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Fatdog2
Feb 13, 2015 08:19 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
Rich_z28
Sep 13, 2002 03:35 PM
