help is needed please!
Old Jan 11, 2012 | 10:36 PM
treyville's Avatar
Angry help is needed please!
I'm getting codes p1637 generator L terminal circuit and P1336 CKP system variation not learned, on my 02 chevy Z28 LS1?? other codes was there: rpm lower in range, fuel bank 1 & 2 lean, I cleared those codes but can't delect last two.. also when I try to write a tune with predator: #invalid Key# stript error Interpreter stopped??? do any one have a solution to these problems? Trey
Old Jan 12, 2012 | 11:38 AM
Marc 85Z28's Avatar
Re: help is needed please!
Check the connector on the back of the alternator, it should have one small wire leading to it. Is it connected? Broken? Wire burnt? If everything checks OK replace the alternator. It would be a good idea to replace that connector and pigtail as well, as that little wire breaks easily and the terminal can spread.
Find someone with a Tech II (or a dealer) and have the crank/cam relearn performed.
What codes? rpm lower in range? Never heard that one. Fuel bank 1 & 2 lean? P0171 and P0174 right? Clean the MAF and inspect the entire PCV system thoroughly for a deteriorated and leaking hose. "Delect" isn't a word.
Sell that POS.
Old Jan 31, 2012 | 04:20 AM
treyville's Avatar
thanks for the help, all your answers was correct...even selling the POS...lol thx.
Old Jan 31, 2012 | 11:36 AM
whitdog54's Avatar
^thats a forum hall of fame answer right there haha. can we sticky this
Old Mar 8, 2012 | 12:58 PM
treyville's Avatar
..lol sure
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
