02 transmission help
Old Aug 28, 2011 | 04:14 PM
badazz's Avatar
i have an 02 z28 and im having some transmission problems. its a 6 spd v8 ls1 engine.. it pops out of reverse and grinds in 5th and 6th gear. what might the problem be with this? am i better off getting a new transmission or rebuilding it .. also where should i go to get the parts or new transmission that i need. im not to familiar with transmissions so if you could help out with any info, it would be greatly appreciated. thanks
Old Aug 28, 2011 | 06:51 PM
byrons1502's Avatar
Re: 02 transmission help
They are not all that hard to rebuild. I am also an ase master tech so it might be alot harder for a rookie or a novice to try. A good transmission shop doesn't charge all that much to overhaul it. As long as there is no major part failures they go for around $700-1100. get an upgrade kit when u build it.
football4life
Oct 4, 2015 07:48 AM
4586
Sep 27, 2015 01:55 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
