241 head question
Old Feb 26, 2012 | 10:08 AM
hot936spd's Avatar
241 head question
Somebody recently suggested to me, to get a set of 241 heads, and fully port and mill them. That they would make a big difference. Saw a set for 75 $. would that be better than going with 243 heads? Thoughts comments??
Old Feb 26, 2012 | 10:20 AM
hot936spd's Avatar
Re: 241 head question
317 heads were also mentioned doing same thing
Old Feb 26, 2012 | 11:10 AM
96capricemgr's Avatar
Helps if we know something about your car and what you want to do with it?
Since you are looking at LS stuff can we guess you are not looking to mod a 93 anymore?
I thought 241s were stock LS1 heads, 243s are LS6 heads and ultimately more capable, but ported 241s should be better than as cast 243s.
317s have the same ports as 243s BUT they have a big combustion chamber for low compression on the truck 6.0l engines.
Old Feb 26, 2012 | 11:18 AM
hot936spd's Avatar
i have a 98 ls1 ta. long tubes, lid, full exhaust, stall, shift kit, 373s. just want some more hp, want more top end, its a weekend car, but would like to be able to drive it to the beach and back. goal is heads, cam and intake. going to start collecting parts this summer
Old Feb 26, 2012 | 11:29 AM
Originally Posted by hot936spd
i have a 98 ls1 ta. long tubes, lid, full exhaust, stall, shift kit, 373s...........
Why not add a "signature" with that info, and avoid people having to ask for more info before they can help you?
Old Feb 29, 2012 | 12:19 PM
raulz28's Avatar
From: 5 minutes from the warzone in mexico(south texas)
317s are more commonly used for boost applications so they aren't optimal for an N/A engine. As said above ported 241s are better than stock 243s but I would recommend ported 243 with a cam in the mid 230s. Before my friend decided to go turbo we specd out an N/A setup and with stock heads we were going to throw in a torquer v2 which is 232/234 I believe so something a little bigger with worked heads should be no problem to be streetable
Old Feb 29, 2012 | 10:38 PM
z95lt1's Avatar
get a set of 5.3 heads mill them, get a cam and spray it.
Old Mar 2, 2012 | 02:28 PM
Marc 85Z28's Avatar
Keep in mind that your 98 uses a perimeter bolt valve cover. If you were to swap the heads to either a 241 or a 243 casting you will need the centerbolt valve covers. Furthermore, the ignition coils bolt directly to the perimeter valve covers, while the centerbolt covers has a bracket that bolts to the cover which mounts the coils.
Old Mar 2, 2012 | 03:43 PM
hot936spd's Avatar
my engine came from gm with 241 heads
Old Mar 3, 2012 | 08:00 AM
Marc 85Z28's Avatar
So you have a replacement engine in your 98?
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
LT14LIFE
Feb 9, 2015 09:35 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Geoff Chadwick
Jul 31, 2002 12:07 PM
