oil pressure?
Old Jun 2, 2011 | 03:45 PM
moondance's Avatar
oil pressure?
Is there anything wrong if the oil pressure gauge jumps around from time to time? Its not a great amount that it does it and ive looked at the oil it looks fine. Usually notice it while its hot and at idle or maybe low rpm. The car only has 64k miles
Old Jun 3, 2011 | 06:27 AM
AL SS590 M6's Avatar
Moderator
Re: oil pressure?
Probably the sending unit getting flaky.
Old Jun 4, 2011 | 09:27 AM
johnny6's Avatar
Re: oil pressure?
Yep the sending unit does very strange things sometimes.
Old Jun 4, 2011 | 03:53 PM
moondance's Avatar
Re: oil pressure?
Ok good. Figured it would be something like that instead of major. Guess it can be flakey all it wants as long as its not hurting anything. The car gets its first treat of GC tonight when I change the oil. Gonna see how it likes it lol.
Old Jun 4, 2011 | 05:36 PM
2001NBMZ28's Avatar
Re: oil pressure?
Reach behind the intake and unplug/replug it while you have the hood up for the oil change.
Old Jun 5, 2011 | 06:52 AM
moondance's Avatar
Re: oil pressure?
Not sure where it is exactly and what will unplugging and plugging it back in do?
Old Jun 5, 2011 | 04:39 PM
2001NBMZ28's Avatar
Re: oil pressure?
Just something easy to check to see if the connector is on tight. It's the black vertical sensor behind the intake on the driver's side. Connector is on top.
Old Jun 6, 2011 | 07:16 AM
moondance's Avatar
Re: oil pressure?
Got a pic of where it is? Im still not exactly sure. The connector that is.
Old Jun 7, 2011 | 05:59 AM
Moderator
Re: oil pressure?
You can't see it. Just follow the the coil packs back with your hand on the driverside and feel just behind the head. Tall round sensor with the connector on top.
Old Jun 8, 2011 | 02:51 PM
Marc 85Z28's Avatar
Re: oil pressure?
I wouldn't attempt to disconnect and reconnect the OEM sensor, especially if you're unfamiliar with it's location. They get VERY brittle with age, and you'll probably end up breaking it.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
