What this noise be?
Old Mar 30, 2011 | 05:36 PM
MeanZ687's Avatar
What this noise be?
I've got the 99 SS LS1, have had it for 6 years now, it just hit 97,000 miles and has never had any problems. Lately though I have noticed an almost constant hissing noise coming from the engine bay. I was wondering if anyone has an ideas what this could be? I also heard that the 98 and 99's oil pumps tend to go out and if there's any early signs before they go? thanks
Old Mar 30, 2011 | 08:41 PM
rv93's Avatar
Re: What this noise be?
sounds like a vacuum leak to me. or maybe a dirty air filter
Old Mar 31, 2011 | 12:36 AM
rod442's Avatar
I haven't heard of the oil pumps making noise when they go bad. dumb question, but are you running the defrost or ac when its making that noise?
Old Mar 31, 2011 | 03:38 AM
L.dookie's Avatar
First thought is vacuum leak. The throttle body gasket went out on my lt1 and it definitely made a hissing/whistling noise.
Old Mar 31, 2011 | 08:37 AM
Chrome383Z's Avatar
Is it running poorly or thowing any codes? If not, maybe your just focusing on it a little too much. I did that when I first got my LS1, thought for sure it had a lifter going bad; turned out it was just piston slap.
Old Mar 31, 2011 | 04:02 PM
MeanZ687's Avatar
well i've had it for 6 years now and I started noticing it. It sounds like it's coming from the engine by the pulley system
Old Apr 1, 2011 | 10:40 PM
L.dookie's Avatar
one way to check and see if it is an intake or vacuum leak is take a spray can of starting fluid and spray around where the noise is coming from while the car is running. if the rpm's go up, it's a vacuum leak. As asked before, does it always make the noise, or does it have anything to do with the HVAC system.
Old Apr 3, 2011 | 07:08 AM
AL SS590 M6's Avatar
Moderator
With the engine stone cold, pull the belt and start her up. See if it's the belt or pulley system.
Old Apr 3, 2011 | 10:27 AM
fstkmaro's Avatar
for what its worth, check the gasket around the air filter cover. They are a pain in **** when it comes to properly seal them. Specially when you have an after market lid, which may not be your case.
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
GT what?
Jul 14, 2015 10:17 PM
colts0455
Jul 7, 2015 07:19 PM
