doing a rering job
Old Sep 22, 2006 | 08:15 PM
mvvette97's Avatar
doing a rering job
Just wondering on my 2000 TA what replacement rings would you use? What brand? Also do I need to hone it before it goes back togethor?
Old Sep 23, 2006 | 08:03 AM
AL SS590 M6's Avatar
Moderator
Re: doing a rering job
Never done a re-ring on an LSx engine but if I did I would call an engine builder like our sponser Victory Racing Engines and get a recommendation from them.
I would at the very least hand hone them if the crosshatch was gone.
Old Sep 23, 2006 | 07:42 PM
WS6NIGHTMARE's Avatar
Curious, why do you need to re ring the pistons? If you hone it you might need oversized pistons.
Old Sep 23, 2006 | 07:46 PM
mvvette97's Avatar
Well I think maybe the rings are bad but i think I'm going to put new valve seals in first. Alot of people have said since it smokes when I let off that sound like valve seals. I'm going to install a cam when i put the new valve seals in. If it still smokes after the new seals then i will start pulling the engine for a rering job.
Old Sep 23, 2006 | 07:59 PM
myslowcamaro's Avatar
i have the same problem even after new heads and valves. only smokes in the high rpm band
Old Sep 23, 2006 | 08:00 PM
A sure sign of bad valve seals is when you park the car overnight, and when you start it up the next day it smokes for a minute while it burns off the oil. Maybe a compression test is in line.
I wouldnt be tearing this engine down because you think you know a solution. Too much time and money to not know for sure.
Old Sep 23, 2006 | 08:01 PM
mvvette97's Avatar
Hmm, mine doesn't smoke at WOT well it does smoke black but not blue. It just smokes blue when I let off or when it idles for a while.
RUENUF
Mar 13, 2016 03:37 PM
pepon214tx
Sep 20, 2015 04:48 PM
Daluchman1974
Sep 11, 2015 06:12 AM
MDZ28
Sep 7, 2015 09:16 PM
