500rwhp 408 iron block how hard?
Switching to lsx engine, was wondering how many have seen, own, or know of a combo that can yield 500rwhp NA. SO many heads and cams out there for these engines, just need a good start and don't want to do everything twice.
Thanks,
Nick
Thanks,
Nick
well hell...Kraest made 471rwhp on a stock cube lsx motor...FM15 cam, dart 225 heads, FAST 90/90
i would think you could pick up the extra 30hp with a little bigger cam and better flowing heads on a 408ci block
fixed.... we all would love to spend more than we have, or at least i know id be spending $20k if i had it right now. eric from vre posted pix of a s88 turbo f-body that was absolutely sick. 1500 hp if i remember correctly. wonder if the 408 block can handle that?
The BigStuff3 GEN3 PRO SEFI system is the first programmable “powertrain” control module for“today’s” SEFI, Coil-on-Plug (COP) engines and
electronic controlled transmissions.
It will basically replace the factory pcm, and control the 4L80e transmission. It will also give us alot more tunability for this high horsepower combination.
Automatics are going to be much harder to make 500 rwhp through than a 6-speed, but nearly any nasty ETP/AFR/ported LS6 headed, 25x/26x duration cammed, with a sheetmetal intake (or FAST 90/90) should have no problem at all making over 500 rwhp through an auto.
Futral built a Meaux LS6-headed, sheet metal intaked, solid-roller 347 that made 512 rwhp through a TH400, 12-bolt, on 28" slicks.
Mike
Mike
Eric what kind of percentage do you find is the difference between mustang and dynojet numbers? 10% ?
Brandon Wittmer
Dec 7, 2014 12:15 PM
Perry93TransAm
Aug 20, 2002 11:23 PM
