Nitrous Outlet Boooooorific Specials
Old Oct 18, 2006 | 11:09 AM
Chris@NitroDaves's Avatar
Happy Halloween everyone.......
Here are this months specials..
Group 1
Nitrous Outlet single nozzle system, Automatic bottle heater, purge, nitrous pressure gauge, fuel pressure safety switch, NHRA fitting, Blow down tube, NGK TR6 Plugs, and our digital dual windowswitch with built in TPS and any gear lock out feature.
Only 999.00
Group 2
Nitrous Outlet dual nozzle dry kit, Automatic bottle heater, purge, nitrous pressure gauge, fuel pressure safety switch, NHRA fitting, Blow down tube, NGK TR6 Plugs, and our digital dual windowswitch with built in TPS and any gear lock out feature.
Only 900.00
Group 3
Our Custom plate system...
Your choice of stock, 90mm or LS2.
billet plate,o-ring gasket,throttle extention bracket,jetting from 50-200,10lb bottle with high flow valve,300 hp lifetime warrenty solenoids with purge port desighn,all mounting hard ware,hoses and fittings..etc
Automatic bottle heater, purge, fuel pressure safety switch, nitrous pressure gauge, NHRA valve and blow down tube.
Our custom Digital Window switch with built in TPS and any gear lock out feature. (will controll 2 stages)
NGK TR6 Spark plugs...
Special price 1,075
Group 4
Your choice of our custom GTO or F-body Halo system, 10 lb bottle with high flow valve, 20 foot main feed line,Stainless steel quick release bottle brackets, 300 hp Lifetime warrenty solenoid with purge port, all fittings, hoses and hard ware.
Our custiom digital window switch with built in TPS and any gear lock out feature. (will controll 2 stages)
Special price 859.00
And here is the perk. When you call in your order with one of the monthly specials make sure to tell your sales rep not to forget your free Nitrous Outlet T shirt.. Make sure to tell them your size.
http://www.nitrousoutlet.com/catalo...odel=60&dept=11
You can call in your orders toll free at 1-866-648-7637
These specials are good until the end of October..
Thank you
Chris
Old Oct 23, 2006 | 09:50 AM
Re: Nitrous Outlet Boooooorific Specials
Bump for a new week. Only 8 days left guys.
-Chris
Old Oct 30, 2006 | 08:54 AM
Bump for the new week.....
-Chris
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
karpetcm
Aug 14, 2015 03:02 PM
Aug 7, 2015 01:26 PM
Aug 5, 2015 08:35 AM
