oxygen senors
Old Oct 17, 2006 | 05:45 PM
Dustin's Z's Avatar
oxygen senors
I have a 00 z28 i was wondering if the 4 oxygen senors i have on my car are all the same? I bought 2 new ones for the front cause ppl at autozone said bank 1 was the front 2, but i later found out that bank 1 is the driver side 2. So i took the one from my passenger front and put it on the driver rear now, and my code is still on, my cats are off, but i pluged my senors back in when i cut them off. Thanks guys
Old Oct 17, 2006 | 06:23 PM
2001NBMZ28's Avatar
Re: oxygen senors
Need more info. What code(s) you throwing? Thinking they're rear codes if the cats are gone? AZ always wants to blame things on 02's, they could atleast get B1/2 and S1/2 right.
Old Oct 17, 2006 | 06:37 PM
Dustin's Z's Avatar
Re: oxygen senors
it is p0420 cat below effiencey level (bank 1)
Old Oct 17, 2006 | 07:08 PM
2001NBMZ28's Avatar
Re: oxygen senors
P0420 is rear (post cat) 02 on drivers side. Did you remove/gut the cats? If so it's normal to throw P0420 and P0430. If that's the case you either need 02 sims for the rears or have the codes turned off.
Old Oct 17, 2006 | 07:32 PM
Dustin's Z's Avatar
Re: oxygen senors
I guess the guy just gutted the cats but i remember he pluged them back in so it would not throw a code. I was thinking where i took the passenger side front and put it on the driver side back if that could be my problem. See i bought 2 new oxygen senors for the front senors.
Old Oct 17, 2006 | 07:53 PM
2001NBMZ28's Avatar
Re: oxygen senors
If the only code was P0420 it was never a precat sensor problem, pretty sure they're interchangeable (make sure they're tight and no leaks), length of the harness might be different though. With stock cats and P0420 usually if the cat is bad it'll throw P0420, under 80K they're covered under the federal emissions warranty.
Old Oct 17, 2006 | 08:04 PM
Dustin's Z's Avatar
Re: oxygen senors
Done to late now i had 95k on them i just cut them off.
Old Oct 17, 2006 | 11:55 PM
AL SS590 M6's Avatar
Moderator
Re: oxygen senors
If the cats are gone or gutted it doesn't matter if you plug the after cat sensors back in, it will still set a code.
If you want the code to go away get O2 sensor simmulators or get a tuner to delete the code permanently.
Old Oct 18, 2006 | 09:26 AM
Dustin's Z's Avatar
Re: oxygen senors
Alright wat would be the best place to get them from and the best deal.
Old Oct 18, 2006 | 12:36 PM
SlowTA367's Avatar
Re: oxygen senors
I ordered my O2 sims from Texas Speed. Pretty much anybody that sells f-body stuff will have them.
Edit: I can't find them on Texas Speed's website, but they are $90 from Speed Inc.
Old Oct 18, 2006 | 05:52 PM
2001NBMZ28's Avatar
Re: oxygen senors
thunderracing.com sells them too - look under "exhaust." Or get a local turner to turn them off, usually they'll charge whatever their one hour shop fee is.
Pwilson59
Sep 3, 2015 08:47 PM
menlatin
Advanced Tech
Jul 5, 2003 05:00 PM
blackz151
May 11, 2003 12:01 PM
blackz151
May 1, 2003 02:25 PM
santomen
V6 Tech
Aug 10, 2002 07:04 PM
