Help I have a strange Revving problem!
This started a few weeks ago.... When ever I get on it alittle bit... say 3500 RPM or higher and then either let off or shift the rpms continue to rise for a split second or longer. It feels like the throttle is sticking open but I checked the throttle return spring and it still has plenty of pressure to it. I also thought it might be some sort of vaccum problem, but I can't find any leaks. I took the TB off and cleaned it, but I still have the same problem. Could it be the electronic idle thing that sits on the TB above the Throttle position sensor?
Please Help.
Thanks,
Matt
Please Help.
Thanks,
Matt
charchri4
Apr 14, 2015 06:40 PM
grabbem88
Mar 18, 2015 01:25 PM
