Low #s?
Old Oct 19, 2006 | 02:25 PM
Klypto's Avatar
Low #s?
mods in sig, but mainly the TR224/224-112 cam, ls6 intake, hooker LT/ORY/catback, on 12 bolt w/4.10s(i know it eats a little HP...)
does 34x (i think 346) sound low? just got off phone with them, they said it runs great/etc, but at idle its a little messed up, but then straitens out...
o yea, its a mustang dyno also... he said hes guessing it would be 370ish on a dyno jet... maybe its right, but most ppl use dynojet?
thanks
cory
Old Oct 19, 2006 | 03:27 PM
soul strife's Avatar
Re: Low #s?
Dude, that does seem low. I know the mustang dyno brings it down but, I would figure at least 400hp with your mods.
Old Oct 19, 2006 | 04:19 PM
93redBirdMan's Avatar
Re: Low #s?
yea thats low for sure. I'd agree that you should be around 400rwhp...
Old Oct 19, 2006 | 06:22 PM
SOMSS's Avatar
Re: Low #s?
No way 400 RWHP, If you had heads also then yes but not with just a small cam. Check my sig for comparison.
Old Oct 19, 2006 | 06:24 PM
SSpdDmon's Avatar
Re: Low #s?
I think that sounds about right. You might have another 5hp hiding somewhere, but I wouldn't expect to see any more than that. You have to remember it's a Mustang dyno (assuming it was loaded during the pull) and you're spinning that 12-bolt. Through a stock 10-bolt on a Dynojet, that cam (with supporting bolt-ons) will usually be about ~380ish. The only time I see those cams in the 400's is with a set of heads.
Old Oct 19, 2006 | 06:28 PM
Greed4Speed's Avatar
Re: Low #s?
Rule #1
You can't compare one dyno's numbers to another.
Rule #2
Dyno numbers are for bragging rights. How does it run?
Mustang Dyno's show lower numbers. 370ish whp from a Dynojet with a 224 cam only is right in the ball park. 400whp (cam only) requires a larger cam in excess of 230 duration. BTW, that 12 bolt will eat some hp on a dyno, but w/4.10s it'll more than make up for it where it counts.
Old Oct 19, 2006 | 06:50 PM
Klypto's Avatar
Re: Low #s?
kk thx all!
Old Oct 19, 2006 | 07:22 PM
SlowTA367's Avatar
Re: Low #s?
That's really close to my setup and I only made 367rwhp, 372rwtq. That's with a lid, pacesetter LTs, TSP true duals, small cam, and tune. Cam is a Bullet custom grind 224/228, .578/.578.
Old Oct 20, 2006 | 06:28 AM
AL SS590 M6's Avatar
Moderator
Re: Low #s?
Mustang dyno shows about 8% less hp than a dynojet.
My combo only shows 400 with the converter locked on a Mustang dyno. but I run 120mph in the 1/4 @ 3450 # raceweight. And that's what counts.
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
68camaroboltz
Oct 5, 2015 01:46 PM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
