valve slap
Old Oct 23, 2006 | 12:03 PM
myslowcamaro's Avatar
valve slap
i have been going back and forth with a couple ideas i have for a engine mod with one of our sponsers. one of them is a rotating assembly. most cranks seem to be 4.00" stroke, with a option for 4.1", how do you tell if that will cause problems with valve slap. i have the prc 2.5 5.3 liter heads, not sure on the gaskets. wish a dish cut piston solve this regardless?
Old Oct 23, 2006 | 02:59 PM
GhostZ28's Avatar
Re: valve slap
you need to check with the advanced tech guys. they know that stuff VERY well. I dont think it causes any problems, because TDC on stock LS1's is about as far as you can go piston peeks out above the deck anyway.
(this is all my own 2nd hand knowledge, so if I'm wrong corrrect me)
Old Oct 24, 2006 | 07:33 AM
AL SS590 M6's Avatar
Moderator
Re: valve slap
You are right, stroking a motor has nothing to do with the piston height. The stroker kit has pistons with raised wrist pin holes to keep the PH the same as stock.
Old Oct 24, 2006 | 02:58 PM
so even with a .600/.605 valve lift i should be ok?
Old Oct 24, 2006 | 03:09 PM
GhostZ28's Avatar
the lift isnt the problem as much as the duration. the best way to tell is talk to someone with the exact same setup or more agressive setup. If they dont have problems then chances are you wont. But all in all, when its all being assembeled, you need to check PTV clearence with all cylinders if there is a chance of touching. Be safe not sorry.
RUENUF
Mar 13, 2016 03:37 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
