Cam Question
Old Oct 29, 2006 | 06:19 PM
red_94z's Avatar
Cam Question
I'm going to get a came for my Ls1 Z and im thinkin either the hot cam or a comp cam that got i think 220/224 .525/.525 specs i think. im not planin on doin head work but i may do rods or lifters what kinda gains could i get from these.(Cars down below)
Old Oct 30, 2006 | 08:11 AM
teke184's Avatar
doing a cam almost requires that you do pushrods, and obviously springs.
with those cams you should se around 375rwhp give or take, maybe slightly less with the high stall.
you could go higher on the lift with a better cam and make some more power.
Old Oct 30, 2006 | 08:29 AM
SSpdDmon's Avatar
Why such small cams? Even with stock heads, you could go with something in the range of a 228 cam and make a little more power without sacrificing much.
Old Oct 30, 2006 | 09:26 AM
darrens99formul's Avatar
I wouldn't even look at a cam smaller then 224/224 114. That is emission passible (with a good tune) and very street friendly. If strict emission testing was not a concern then I wouldn't be afraid to step it up to a FM13 or even a TSP 233/239 if you ever planed to spray.
Cams are a lot like torque converters. If you go too small you are almost guaranteed to regret it later and want bigger. But obviously you don't want to go too big so I won't recommend a Trex or MS3
Good luck.
Old Oct 30, 2006 | 09:32 AM
Kraest's Avatar
Retired
The Futral F-13 is basically the best cam you can install in an LS1. Near-stock driveability with a slightly lopey idle along with good gas mileage and great power.
Old Oct 30, 2006 | 10:17 AM
red_94z's Avatar
Oh, well i was going to do the small cam b/c my Z needs a lil more on the top end i keep havin guys pull by me at the other end. So if i do, say the F-13 what kinda power will it give me, and were can i get one of them?
Old Oct 30, 2006 | 10:19 AM
teke184's Avatar
www.futralmotorsports.com
i would guess you'd be in the 390-400rwhp range...depending on the tune and how much the stall and gears soak up.
Old Oct 30, 2006 | 10:24 AM
red_94z's Avatar
Well, its not all a/b power its what ya do with it that makes the good et. But since i do alot of bracket racing its not all a/b goin fast for me i just dont wanna get beat by anothe honda civic with a turbo in a heads up race... Neways thanks i think the f13 should do the trick.
Old Oct 30, 2006 | 12:31 PM
GhostZ28's Avatar
you may want to reserve one soon. When I called to buy mine I was on a waiting list for about 2 weeks because F13's are always sold.
Old Oct 31, 2006 | 08:02 PM
red_94z's Avatar
GhostZ28 I dont know if u go to the strip much but when you did ur H/C set up what kinda gain did u get n et?
Old Oct 31, 2006 | 10:30 PM
GhostZ28's Avatar
I havent actually done hte H/C swap... I've been waiting for my father to build his new car shop so that I can get to work and have a new beast to drive next summer.
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
