Dual remote oil filter kit...
Old Oct 19, 2006 | 06:31 PM
SOMSS's Avatar
Decided that it might be a good idea to get some clean oil running through my nice new high performance motor. So I got this:
Brand: Trans-Dapt Performance Products
Product Line: Trans-Dapt Performance Remote Oil Filter Relocation Kits
Thread Size: 13/16-16 in.
Oil Filter Quantity: 2
Oil Filter Included: No
Hoses Included: Yes
Hose Length (in): 30 in.
Fittings Included: Yes
Hardware Included: Yes
Diesel Compatible: No
Marine Use: No
Bracket Material: Aluminum
Bracket Finish: Polished
Quantity: Sold as a kit.
Notes: 2.500 inch ID, 2.750 inch OD O-ring included. Use Ford style oil filter with 3/4 inch 16 thread.
Oil Filter Relocation Kit, Dual Filter, 30 in. Length Hoses, Kit
Only costs $52.95 for the dual kit and $16 for the two K&N oil filters.
P.S. Anyone that needs a Mobil 1 oil filter let me know, as I now have an extra filter.:thumbsup:
Old Oct 19, 2006 | 07:10 PM
StudyTime's Avatar
Re: Dual remote oil filter kit...
This beggs the question is it necessary or even practical?
Ben T.
Old Oct 19, 2006 | 11:23 PM
GhostZ28's Avatar
yeah i'm wondering the same thing.. Is it WORTH 50 dollars and an extra filter every change? If this will almost eliminate metal and carbon particles, then hell ya i'm buying one..
Old Oct 20, 2006 | 05:00 PM
SOMSS's Avatar
It's worth it to me! As for it being worth it to you I don't know. An extra quart of oil and twice the filtration, seems worth $50 to me.
Old Oct 21, 2006 | 09:17 PM
Greed4Speed's Avatar
How about spending $40 on some oil analysis to see if you even need double filtration?
You'll probably find out you'll save $8/oil change on the extra filter and most likely find out you can go longer between oil changes if running synth.
If you're THIS worried about your oil, IMO an oil analysis would be a logical preliminary step.
The other thing to think about is how will this set up effect your oil pressure?
Old Oct 23, 2006 | 06:32 PM
SOMSS's Avatar
My oil pressure is about 70lbs running and 60lbs at idle. I am not concerned about the quality of my oil, I use Amsoil 0W30 and change it and the filter every 7500 miles. I want my nice new rebuilt engine to last a long long time. I have already done oil analysis and it turned up nothing unusual or bad.
Old Oct 23, 2006 | 09:11 PM
GhostZ28's Avatar
I'm buying one.
Old Oct 24, 2006 | 05:42 AM
StudyTime's Avatar
How much more power do you expect it to eat up? Having more head losses through your oiling sytem is going to cause your positive displacement oil pump to consume more power.
Also, you probably wouldn't have to change the second filter. I doubt it would see an appreciable amount of metal. Maybe service it every three oil changes?
Ben T.
Old Oct 27, 2006 | 07:11 AM
ocshaman's Avatar
Ben T.
If I remember correctly, the filters run in parallel. It's not a dual with bypass, so it should be parallel.
Old Oct 27, 2006 | 09:55 PM
That is what your prussure is NOW, but it may very well be different after this.
Also, if your oil analysis was OK with your change interval, I can't see where running another filter is going to help. Its just overkill and possibly requires more volume than your oil pump can efficiently handle which would actually reduce the efficiency of your oil system. Kind of like when people run high volume oil pumps for better oiling but they don't realize that it can suck the sump dry at high RPM's.
Just some things to research before buying it just because its an "extra filter." More isn't always better.
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Jul 4, 2005 05:00 PM
97 RedSS
Jun 10, 2003 07:58 PM
