Need opinions on which block to choose
Old Sep 24, 2006 | 04:58 PM
OreoLT1's Avatar
I am putting together plans for a ground up engine build for an 02 Z28. I am currently running an STS kit @ 5psi. on an LS6 block and the STS will be carried on to the project motor.
I was thinking of using the 6.0L iron block for a foundation. Any input on this block and it's capabilities would be much appreciated! I saw an LS iron block on GM Parts Direct p/n 12572808 9.240" deck height, 3.98" bore, 6 bolt main, nodular cap material, standard LS crankshaft journal diameter. wet oiling, 1 piece seal, 4.00" max stock, 500 max horsepower, street usage, LQ9 origin
Would this be an acceptable block for this build up? Plans are looking like to stroke it, run around 7-10 psi. boost level, no No2, no sure baout cam, intake, valvetrain and specs. on bottom end. Just trying to take this one part at a time to ensure a proper build.
Any input would excellent and appreciated.
Old Sep 24, 2006 | 07:00 PM
MachinistOne's Avatar
Re: Need opinions on which block to choose
An aluminum block will handle that power no problem, don't add the weight of an iron block.
Old Sep 24, 2006 | 09:01 PM
streetbad's Avatar
Iron block will be fine $600. A better choice might be a l92 block $1200 with l92 heads $174 each (330 cfm!)
Devinfoote87
Feb 12, 2016 03:21 PM
MikeWhitener
Aug 2, 2015 06:17 PM
birdblack
Jul 8, 2015 07:23 AM
camaro02DK
Jul 5, 2015 09:04 AM
carl.froehlich
Mar 13, 2015 12:38 AM
