2001-2002 Intake Question
Old Sep 29, 2006 | 04:47 PM
aerojt's Avatar
Is it true that the 01 and 02 LS1's got the LS6 intake manifold stock? I looked at an SS the other day and the owner claimed that to be true. Just curious, thanks!
-JT
Old Sep 29, 2006 | 04:50 PM
2001NBMZ28's Avatar
Re: 2001-2002 Intake Question
Yep, it's true.
Old Sep 29, 2006 | 04:54 PM
aerojt's Avatar
So i'm looking at my 2000 and 2001 brochure and the hp difference isn't huge, what was the advantage and is it a huge difference? Thanks
-JT
Old Sep 29, 2006 | 05:10 PM
myslowcamaro's Avatar
while they got a slight gain from the intake, they (01-02) had as lightly milder cam to offset the gain.
Old Sep 29, 2006 | 06:13 PM
Bayer-Z28's Avatar
THe LS6 intake has a nice gain over 98-00 LS1 intakes... My buddy dyno'd 347rwhp w/ just a lid, P+P'd THB and a catback!... he's got a 2002 SS BTW...
I have differances (w/ linx to pix) between the to explained in my "LS* Info" stickey at the top if you want to check it out...
Old Sep 29, 2006 | 09:46 PM
94mula's Avatar
The cam is not to offset the gain. The cam is milder to clean up emissions so that the EGR is not needed.
Old Sep 30, 2006 | 08:11 AM
i wasnt saying it was intended for that, just that a milder cam does indeed offset the gain.... good point about the egr, i forgot about that one.
Old Sep 30, 2006 | 05:03 PM
Bevenue's Avatar
yes it's true, also the ls6 intake has blow plugs so you don't explode it when it gets supercharged or turbocharged. I don't think the ls1 intake has them. ls1 on the left, ls6 on the right
Old Sep 30, 2006 | 06:00 PM
bowtiepwr's Avatar
>so can you put the intake from a 2001 - 2002 on the heads from a 1998 - 2000 LS1?And will it be worth it?
Old Sep 30, 2006 | 06:05 PM
yes and yes. a used ls6 intake is like gold on here. if listed for sale they dont last long cause us 98-00 ls1's want one badly
bevenue.... where are the blow plugs in the pic?
Old Sep 30, 2006 | 09:35 PM
Bayer-Z28's Avatar
I've NEVER heard of the LS6 intake having blowoff ports. The FAST intake has them for an option.
Old Oct 1, 2006 | 09:46 AM
AL SS590 M6's Avatar
Moderator
It doesn't. I've seen a NO2 backfire blow one to bits and pieces.
Old Oct 1, 2006 | 05:56 PM
psychocabbage's Avatar
everyone says that the "milder" cam hurt power gains..
But all too often people are comparing the marketing brochures..
I find that the different cam gives us more power all arond.. We have some realy good low end torque.
Old Oct 7, 2006 | 03:45 PM
ZROC86's Avatar
So would putting an LS6 intake, heads, and cam on an LS1 block essentially make it an LS6? I know the LS6 block had a different casting but the displacemt was the same.
Old Oct 7, 2006 | 04:09 PM
GhostZ28's Avatar
yes it would be the same thing essensientially
