cam question
Old Dec 1, 2006 | 02:49 PM
NORALTA's Avatar
cam question
i need some cam suggestions for an engine build.
i'm putting lt's, true duals, fast 90/90 intake tb, ls6 heads (not ported but upgraded springs etc.), 3.73 gears and want some suggestions on brand and size for a cam. I plan to computer tune and change the stall but, I don't want to have to run a stall over 2500 rpms because it'll be a daily driver.
Could you tell me what i need and what i should expect to get with this set up rwhp. If you don't know who can i contact?
Old Dec 1, 2006 | 03:19 PM
myslowcamaro's Avatar
400-430rwhp depending on the cam you finalize. some people like the futural brand cams (kraest pushes that hard) i have a tsp custom cam and happy with it. a decent stall with that setup should put you in the mid 11's with dr's
Old Dec 1, 2006 | 06:39 PM
SOMSS's Avatar
With stock heads I would look for something in the 224/228 LSA 114 with a lift of .580/.580. Of course cam selection depends on your type of driving and goals. Peak hp numbers don't mean much, it's much more valuable have a high average hp under the curve.
Old Dec 1, 2006 | 06:57 PM
Greed4Speed's Avatar
Thats too small for a STOCK LS1, much less a camed one.
Old Dec 2, 2006 | 08:34 AM
AL SS590 M6's Avatar
Moderator
Ditto, think 3500 and don't worry about daily driving one. With the new converters high efficiency and lock up features it's not a problem at all.
Old Dec 2, 2006 | 09:27 AM
what are the stock tc's rated at? im still running stock
Old Dec 2, 2006 | 11:17 AM
Kraest's Avatar
Retired
If I had to guess, I'd say somewhere around 1500 or so.
I'm running a 2400 stall, although it's a little bigger with a blower. I really need a 3600 and this bitch would be in the 10s easy. It wastes too much time getting into boost from a dead stop.
I'd say to get a Futral Motorsports F11 or F13. Both have been successful in making over 400 rwhp with all supporting mods. The F11 is a little smaller, so you won't need much of a stall, however, just as everyone else already said...... a STOCK LS1 really needs a 3500+ stall since it makes peak torque around 4000 rpm.
Mike
Old Dec 3, 2006 | 09:23 PM
1stls1's Avatar
Will the stall affect you after you are already moving(hurt midrange)?
Old Dec 4, 2006 | 08:58 AM
Kraest's Avatar
Retired
No, it helps everywhere.
Old Dec 4, 2006 | 11:27 AM
NORALTA's Avatar
what brand cam??
What brand cam do you guys suggest?
Old Dec 4, 2006 | 11:41 AM
teke184's Avatar
you didn't indicate a hp goal??
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
