fuel rail covers from a vett
Old Sep 18, 2006 | 12:08 AM
niko's Avatar
What year corvette with a ls1 fuel rail covers will work on a 1999 ls1 camaro ss, and how do they stay in place ???
Old Sep 18, 2006 | 10:37 AM
350 HRSS's Avatar
Re: fuel rail covers from a vett
I think it is the 2001 Vette that will fit the 99's. You need to go to your dealership and get them to pull a pic of them up on the screen and see which year has two fuel line openings. You will need the one w/ the two fuel line openings. I made this mistake myself, and ordered the 99 vette covers thinking they would be the same. Please be sure to check the years yourself, and not take my words for solid truth! It has been over 3 years!
How do they fit?
You will need to cut these to make them fit correctly. On the pass. side, you will be cutting quite a bit off the rear of the cover, the hole for the dip stick, and a slot for the throttle cable bracket.
On the driver's side, you won't be cutting as much. You need to try to fit them on, and cut a little as you go. It will take a few hours, maybe, some patience, and your dremel tool.
They end up fitting well, and as long as you take your time, you shouldn't have any problems.
HectorM52
Jul 30, 2017 11:46 AM
QuickSilver02
Apr 7, 2015 11:12 AM
4586
Feb 13, 2015 09:16 AM
maybe2fast
Feb 5, 2015 05:14 AM
Jul 4, 2005 05:00 PM
