Misfire at idle
Misfire at idle
The car has a misfire at idle code P0300 engine misfire detected. I pulled the spark plugs the drives side looked all good put the passager side were soild black. All of the wires are good. Has buck when driving around 1700-2000 put under high rpms it pulls good. Dose any one no what it could be?
Sean
Sean
Re: Misfire at idle
I had the same issue when I got my car.....except no code.....I found a spark plug wire that had a split up the center of the boot allowing it to ark in the little silver sleeve thingy. Of course you cant see it because its it the sleeve..... just something to check.
Nayr
Mar 3, 2023 08:34 PM
tdigger9899
Sep 7, 2015 10:56 AM
