Where does your temp gauge sit w/ the 160* stat?
Old Sep 17, 2006 | 01:10 AM
Bayer-Z28's Avatar
Like it says. Where does your temp gauge sit with the 160* t-stat?
I did mine today and It's sitting at a constant 200.
I figured with the cooler stat, it would sit a bit lower. But, come to think of it, engines produce heat and it transfers over to the coolant. THe t-stat would only effect when the coolant starts flowing thru the radiator, from the engine block.
Hmm.... Just a thought. I also accidentally mixed pre-mixed coolant(didn't notice till it was too late). I did a flush a long time ago and there was still DEX in the engine block... WTF?! I thought I flushed all that! Wouldn't it have mixed and circulated by now?
Old Sep 17, 2006 | 07:59 AM
MEAN LT1's Avatar
Re: Where does your temp gauge sit w/ the 160* stat?
It does no good to have a 160 stat without reprogramming your fans to match.
Old Sep 17, 2006 | 11:52 AM
GhostZ28's Avatar
I think alot of it has to do with the gauge that reads only "cold" "warm" and "hot"
Old Sep 17, 2006 | 12:43 PM
2001NBMZ28's Avatar
The '99 and up gauges all read just under 210. I have a 160 and fans set at 184/175 and 194/185 and does the same.
Old Sep 17, 2006 | 01:37 PM
Bayer-Z28's Avatar
I had my fans reset when I had my LS1 Edit a couple yeas ago.
I read a post a while ago that asked abot the "phony' temp gauge that only reads, like said cold, warm and hot....Is that really true?
Old Sep 17, 2006 | 02:19 PM
2001NBMZ28's Avatar
On mine the first mark on the gauge is 142* on a scanner, wanted to see when my converter would lock at part throttle after the install. Watched it climb - once within "range" (whatever that is) it settled just under 210. It did go a little above 210 a couple times sitting in traffic at lights in very hot (95*) weather after installing FTRA, and not running the AC before lowering the fans.
Old Sep 17, 2006 | 03:56 PM
CamaroSS30thAnn's Avatar
on my 97 i have the 160 stat and teh fans reprogrammed, i usually sit around 170-175
Old Sep 17, 2006 | 06:24 PM
GhostZ28's Avatar
Hey Rich, yeah its really true about the guages. Its kinda scary that you dont really know the temp of your car unless it overheats.
Old Sep 17, 2006 | 07:02 PM
Bayer-Z28's Avatar
I'm still smeliing the coolant that ran off douring the install. I couldn't hose it down, shoulda taken it to the car wash while I was out today.
Still sits at about 200.. odd... I'll have to recheck the level too. I even threw in some Purple Ice, water wetter stuff.
Old Sep 17, 2006 | 11:48 PM
99_Z_155's Avatar
I have a 99 and i have the 160 stat. mine used to stick right at 210 like said before, but now it is actually SLIGHTLY lower. like maybe 10 degrees. kind of strange.
Old Sep 18, 2006 | 11:46 AM
350 HRSS's Avatar
It's true about the phony gauges like one other post mentioned earlier. They really are only good for showing you if your engine is over heating.
I have a Mezeire on mine, it comes w/ a 160* and my fans have been reprogrammed as well. W/ the Meizere turning out 55 gpm, I know it has to be much cooler than the factory pump.
Most of them I know of will sit on 210*, even driving in the dead of winter on a 30* day.
Old Sep 18, 2006 | 09:57 PM
teke184's Avatar
"It does no good to have a 160 stat without reprogramming your fans to match."
that's the biggest load of CRAP that gets proliferated on this board
i guess you probably think that your fans have an affect on your coolant temps when you're running 45mph through the twisties...or better yet 70mph on the highway.
the only times that your fan settings have much of an affect on performance is when you're sitting in the staging lanes. and even then you'll have so much heat soak it really wouldn't matter if they were reset or not.
i guess you could say you'll take advantage of the fan settings when sitting in rush hour traffic...cause we all need that 5hp boost due to lower engine temps when we are in bumper to bumper traffic
i drove for 2yrs on a 160stat in my LT1 with stock fan settings and took full advantage of the lower temps 95% of the time. even in mild traffic the temps would never climb enough for the fans to turn on.
i've watched the coolant temps on my LS1 (scan tool) down here in south florida heat and the coolant runs between 170 and 180 even in stop and go traffic (not rush hour).
so tell me why i need my fans reset?
in stock temps they are sufficient to prevent overheating (assuming all else is OK)
Old Sep 18, 2006 | 10:02 PM
Bayer-Z28's Avatar
Originally Posted by teke184
"[i]i've watched the coolant temps on my LS1 (scan tool) down here in south florida heat and the coolant runs between 170 and 180 even in stop and go traffic (not rush hour).
That's all I needed to know. It gets wicked hot here too. I was on my way to work this morning, it was DANG chilly out too, I had my heat on, didn't feel HOT like the 210* temp gauge was reading... I had it on full heat too.
Old Sep 19, 2006 | 07:08 AM
teke184's Avatar
that could be a problem with the heater...not the heat itself
Old Sep 19, 2006 | 12:58 PM
Bayer-Z28's Avatar
^^ Nah, the temp gauge leveled off for a minute at about 170*... I wasn't driving for more than 10 minutes... It warmed up a little, the leveled off at 170 then climbed to 200 and stayed..
my heater works fine.
