engine knock?
Old Dec 5, 2006 | 05:17 PM
98blckz28's Avatar
engine knock?
so i was running my buddy in his mustang... and we stop and i start hearing a knocking sound coming from the engine.. my oil pressure went down to 40 and when i gave it gas the knocking sped up. no oil leaks... could this be a bad oil pump? any suggestions? thanks
Old Dec 5, 2006 | 05:44 PM
VinceTrifecta's Avatar
It's probably a spun bearing.
Old Dec 5, 2006 | 07:56 PM
Capn Pete's Avatar
What type of mileage on the car? How long have you had it? This is definitely something new, and not the normal LS1 tick/clatter/knock sound??
If it's definitely a new sound, and the oil pressure has taken an obvious drop, then yeah, sounds like a bearing gone .
You might want to pull the oil filter and cut it open; inspect the filter media inside for metal filings/shavings ..... that's often a good indicator of parts failing.
If this is the case, time for a nice LSx stroker motor!!!!
Old Dec 6, 2006 | 07:16 AM
teke184's Avatar
pull the valve covers and check for broken springs, loose rockers etc...
Old Dec 6, 2006 | 08:06 AM
98blckz28's Avatar
so yeah i went and looked at it again last night and checked the oil level and it was low... i put two quarts in and it did nothing... no leaks or anything. Still making the same noise. I am thinking it now may be a rocker. If so so much will this be to repair?
Old Dec 6, 2006 | 08:49 AM
teke184's Avatar
depends on exactly what's broken...
could be bent pushrod, broken spring, messed up roller bearing on the rocker.
all are gonna be a few hundred to fix.
good time to upgrade
Old Dec 6, 2006 | 09:14 AM
Kraest's Avatar
Retired
2 quarts is kinda low to be racing.
I'd be surprised if you didn't spin a bearing or something.
jayblev95
Dec 1, 2014 06:55 AM
Jul 4, 2005 05:00 PM
Lions3
Apr 11, 2003 10:55 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
