Full Tune up
Old Oct 14, 2006 | 11:27 AM
kevinCHOPTICON's Avatar
Full Tune up
I have a 2000 Camaro SS M6 w/ 82,000 on it so I decided to finally go ahead and tune her up. So far I've got MSD 8.5mm plugs and NGK TR55 plugs, a Radiator coolant flush, Transmission flush, rear end fluid change.
Also went ahead and got a slp cold air pac and 160* stat to put in. already had full exhaust. What else would you recommend to tune her up and keep her running good.
Old Oct 14, 2006 | 11:40 AM
mook99TA's Avatar
Re: Full Tune up
Fuel Filter
Old Oct 14, 2006 | 11:51 AM
landstuhltaylor's Avatar
Re: Full Tune up
seafoam
Old Oct 14, 2006 | 01:04 PM
Re: Full Tune up
sea foam?? never heard of it, what's it do. Oh yeah and I got my buddy that works at Jiffy Lube to hook me up with their fuel system cleaner and changed out my fuel filter. It was supposed to be like 90 bucks but he charged me like 30.
Old Oct 15, 2006 | 09:41 AM
teke184's Avatar
Re: Full Tune up
$90 ....hell even $30 for a fuel system "clean out"????
an $8 can of seafoam and a $4 fuel filter would have gotten you the same result.
seafoam....do a search...been discussed MANY TIMES
Old Oct 15, 2006 | 07:33 PM
GhostZ28's Avatar
Re: Full Tune up
if you dont want to research, Seafoam is in a small white metal can with a plastic screw top. It costs about $5.50 for a can.
You put it in your fuel tank to clean the fuel system, you put it in the oil to clean out the crankcase and help rings seal better, and you also put it in a vaccuum line (most use brake booster line) to suck it up in the combustion chamber while its running to de-carbonize the heads and pistons.
SEAFOAM IS MAGIC!
Old Oct 15, 2006 | 07:56 PM
Re: Full Tune up
hm ok well since i got my fuel system cleaned already you think i should still get the seafoam or do you think it's good enough now
Old Oct 15, 2006 | 08:21 PM
mook99TA's Avatar
Re: Full Tune up
seafoam can also be used to put in your crank case to clean your engine and in a vacuum line to get into your cumbustion chamber so I would say yes.
Old Oct 15, 2006 | 08:40 PM
myslowcamaro's Avatar
Re: Full Tune up
any negative feeed back on the seafoam at all? got tired of trying find some in all the previous posts.
Old Oct 15, 2006 | 08:45 PM
Re: Full Tune up
if anybody has questions about seafoam, i shall refer you to this page
http://www.ls1tech.com/forums/showthread.php?t=534376
Old Oct 16, 2006 | 02:37 PM
GhostZ28's Avatar
Re: Full Tune up
there has been SOME negative feedback on seafoam. On some engines, its the dirt and grime and carbon holding them together. Seafoam has unclogged some old dirty engines in which the dirt was keeping the rings sealed, or carbon was keeping the bearings true. but an LS1 wont ever have that problem so seafoam on.
DirtyDaveW
Dec 1, 2016 05:37 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
InfernalVortex
Jan 17, 2015 09:35 AM
nophix
Nov 30, 2014 10:26 PM
Nostang 96z
Aug 31, 2002 12:01 PM
