- Carburation Blues...
- do I need a new starter?? Please read
- Fuel injector lbs
- 2.8L 84 Camaro misfiring on acceleration
- Solutions to my car running really fuel rich.
- Open Element
- What are my chances?
- what's the trick to seating the tranny pump?
- convertible top questions
- How many 91-92 trans am verts were made??
- Im new so please help
- camshaft
- Color code
- Speedometer Question. I did search.
- Just wanted to say whats up.
- H.O. Dual Snorkle swap
- '82 Z28 questions
- Need some advice bad...
- Car won't start after sitting for 30 mins
- WTB: '89-'92 305 TPI 5speed Camaro
- Where to buy a stock TPI alternator pulley for 88 IROC
- TPI performance????
- cleaning out 3rd gen stuff avail
- A/C too cold?
- Will 87 Firebird interior fit my 88 camaro?
- 86 z28 options
- Brake upgrade
- Rim Question
- don't want them oval rims
- brake
- Will 97+ 5 Spoke Rims fit my 84 TA?? anyone know??? read!
- speedo cluster question?
- how do i remove fuel pump
- Rough Idle
- new exhaust sound!!!
- new guy !!!!
- 86-iroc no spark help!
- installing fuel tank
- bad blow by and what causes it?
- I did not know where else to post this.
- Lookin for pics of 305/350 TB, front view
- spohn performance brake kit
- installing a new motor soon!
- I need help!
- Were the 92 stripes painted on or stickers?
- I'm buying an 89 Formula and I need your opinion
- anyone have 1992 camaro rs specs......
- Dumb question?
- Opinions on mud flaps/splash guards
- Where to buy diagnostics programs.......
- fuel pumps
- Problem
- Pop-up headlight sticking
- Best source for new GM ring & pinions?
- 1988 block info
- 1 LE brake
- Any recomendations for an intake?
- 3rd Gen LS1 swap
- FOUND!!!!!!!!
- Rebuild a T5???
- Timing on TPI
- Tail Lights ?????
- Lock-up connector on 88-92 700r4 trans ...question
- Egnition switch
- smog pump removal
- Best Shop Manual?
- AC retrofit
- Are there any kits sold to lift the back end of a Z 1 Inch?
- Help!! Bad hesitation @3000rpms in 1st gear
- is .045 to much of a gap on my Rapidfires????
- Almost forgot
- Newbie - Tire size on stock '88 rims
- Smoke on start up
- Will a bigblock fit in a 3rd gen?
- gm fastburn heads?
- Radiator Need help!
- Running duel exhaust. Don't tell me it can't be done.
- 700r4 rebuild kits
- Will the shorter iroc front springs fit on a normal z
- stumble at cruise speeds
- T-5 Trans and QuadraJunk QUestions. 83 Camaro
- Oil pressure question.
- help me
- Need Help With Magnum TPI Project Car--Induction Solution Needed
- Whats the part # for a K&N that clamps on the TB?
- What size engine came in 90 IROC?
- KYB Opinions??
- Will l98 heads bolt up without any problems?
- What can be causing this misfire/stuttering??
- Bad click/pop noise at low RPMs after build up
- 91 Camaro for Sale, New Engine
- march power and amp pulleys on an 89auto.
- Rear end noise?
- My car is acting odd....
- snapped bolt!
- TH-350 installation
- Need some help on headers install.........
- Someone wanna help me choose my next upgrade
- value??????????????
- 3rd Gen/2nd Gen Fbody chief at Bowling Green
- Why is my car ideling hot?
- Seat covers...Are they worth it???
- Magnecore Wires???
- how to set timing
- the dreaded thud from the rear suspension
- Shifter "hop"
- Idles High
- AFTERMARKET CAMARO COMPUTOR
- Alternator good, but not charging... (starter related?)
- Stroke a 350 to 383????
- Camshaft upgrade...
- Still debating engine options... opinions needed
- What would I have to buy to run a 383?
- Anyone ever hear of S&W racecars or own any of there stuff??
- Tranmission problems
- Need Help!!
- trunk area
- Stealth Ram install pics
- roller rockers
- holley stealth intake
- spintech mufflers
- Attention 3rd gen historians... QUESTION...
- What up with Spohn!!!
- 24# Injectors will they be to much
- Gas tank dilema..................
- Need help tuning!
- Forging Differences 5140 vs 4130 vs 4140
- Turning a 305 into a 350?
- Aftermarket Fuel Pump
- Weird Problem
- F-Body, yes or no.
- Lost in the terror
- 85 Iroc Fuse Layout????
- Anyone ever put LS1 front brakes on a 3rd gen?
- Need pics of air box baffle mod.
- Banks twin turbo kits
- Blazer 700R-4 Tranny??
- MY CAR WILL NOT QUIT SMOKING! HELP
- What clutch to get????
- parts
- lt1 runs, now have a header question
- after market MAF sensor
- engine restore?
- Spohn torque arm problem
- Clutch pedal issue........Please read
- Do I have too many miles for ...
- Ideal Project Car Q's
- Guys with 4th gen consoles in 3rd gen's look inside
- n00b question
- Is my BBC a freak?
- t56 problems
- removal of dampener
- Rear Deck Lid
- Harris County anybody? Emission probs.
- NEED HELP WITH THROTTLE CALBLE
- Newcomer :/
- Stock 305 TBI cam specs
- If you have a 91/92 Z28 I need info from U.
- Rear End Noise Click & Scrape
- Aftermarket Rear End
- Question for anyone with an aftermarket shifter ( Auto )
- What did the TPI cars get that TBI didnt?
- Need help with vortec heads
- 700R4 to a Turbo 350
- Anyone good with Quadrajets?
- 2nd gear's crunchy
- I think my coil is stock but my distributers not??
- pilot bushing removal
- opinions from people with experience with headers
- Timing
- Cranks long time before starting
- Rear Diff Question...
- 92 RS-throw in an LT1-good or bad idea?
- Has anyone ever done this?
- Exhaust system Q.
- I need paint codes for a '87 T/A
- putting in a 305
- Anyone with a 4th Gen console? I have questions...
- help me
- 87 305 IROC-Z mods?
- 90 RS with IROC hood
- Not throwing codes.
- Headers for a 305 TBI
- Has anyone done TBI - TPI conversion ?
- Open element for TBI
- Opinions... dont know anything about 3rd gens.
- New Rad for an '84 Z28
- anyone know aplace that ships used parts
- Any modifications for these wheels????
- Exhaust question
- Headers?MSD?Converter?
- Where could I get a dual fan setup?
- Anyone know where I could get a good chip burned?
- Fuel press. regulator
- TB Bypass
- TPI Plenum
- Pilot Bearing
- Weight of Conv Iroc-Z
- headers and exhaust!
- Anybody order from 9bolt.com?
- Something isn't right ..
- What type of applications require a different MAF?
- dyno #s for iroc-z
- help!!! installing manual steering box
- Pics of TT hood on a 3rd gen?
- added some new pictures
- Cam swap into my LB9??
- Plenum?
- New Engine Specs
- new to thirdgens
- K&N filter & exhaust
- 350 TBI/HO Crate motor
- Strip Wheels or Paint?
- 86 Berlinetta v-6 stick to 305 auto turbo350 ...not shifting right.....
- New kid, got alot of questions.
- Camaro 350 TPI times?
- Question on Gapping the spark plugs i just bought
- How hard is it to change ignition?
- Timing increases as car heats up?
- Power Pack Exhaust on 89 RS+?!
- Seat Belts
- Catco dual cat LASH UP
- shifting late
- computer and stereo problems
- Rearend and Ring and Pinion
- 1991 RS Starter
- LS1 V8 camshaft
- Missfiring!
- New guy.... got some questions...
- Fastchips?
- Rocker Arm Questions
- 91 TPI Z28 won't start until it has cooled down.
- camshaft for 1991 RS 5.0 TBI
- When is descreening your MAF a good idea?
- 1991 RS 5.0 TBI
- New gears...how to fix speedo???
- how rare is this?
- What should timing on a 383 be?
- I need aCold Air induction
- Anyone ever used dry ice on there intake?
- Audio Problem
- Damned Electrical Problems!
- black smoke
- light blue smoke from tail pipes
- Failed inspection: Smoke coming out after being online for lone time!!! NJ
- TPI Track Times
- How long does it take to break in a rebuilt engine?
- Anyone know how many CFM stock fans pull?
- Rims and tires
- how important is TC lock up?
