how important is TC lock up?
Old Aug 2, 2002 | 12:19 AM
phoenix916's Avatar
Post how important is TC lock up?
I recently put a LT1 in my 92 bird with 700r4. I bought a lock up kit but the switch will not work with that motor (vacuum). I know that the tranny will probably run a little hotter and supposedly get a little worse gas mileage but will it effect power if the tranny doesn't lock up? I'm thinking of using a window switch or making a switch for the pedal but until then it will not function. They sent me a vacuum switch that activates with vacuum at throttle but the LT1 has no vacuum at throttle does anyone have any ideas on what I can do? Thanks
in advance.
Old Aug 2, 2002 | 12:37 AM
Sitting Bull's Avatar
Post
Don't really have a solution for it but lockup generally only happens in Drive or Overdrive, once the car is at a speed where the engine's torque will be able to sustain the car's momentum. On the highway it would hurt mileage but in the city I doubt if you see too many cases where the lockup would occur.
[This message has been edited by Sitting Bull (edited August 02, 2002).]
Old Aug 2, 2002 | 11:12 AM
newby's Avatar
Post
On my car my tranny will only lock up in overdrive, and it usually does it at around 40mph. So if I'm just cruising it definately helps keep the rpm's down a little bit, especially on the freeway.
1986 Z28
383 ci Stroker, Dart Sportsmen 2 heads, roller rocker arms, Crower Hot Street Beast cam, edelbrock 750cfm carb and performer rpm intake, Corvette Servos, shift kit and 2600 rpm stall convertor, 3.73 gears and Eaton limited slip posi rearend.
Old Aug 2, 2002 | 05:30 PM
AutoRoc's Avatar
Red face
Since I put a carb on my car, lockup has not been working...Doesn't bother me actually like I thought it would. 70 MPH still shows me roughly 2100 RPM with my 3.08 gears. I am pretty sure that's about 100 RPM higher than with the lockup! not bad at all...
Denny Villemure
1989 Camaro IROC-Z Convertible, 305 TPI, 2.73 Gear, Flowmaster 2 chamber. 15.60 on motor, 14.20 on a 75 shot from NX. Woo hoo!
www.denny.cz28.com
Old Aug 2, 2002 | 05:48 PM
IrocSS85's Avatar
Post
lock up only occors in 3-4 gear. you can make a manual switch by simply applying power to the tcc wire in the 4 pin conn. in the 700r4. should be about 2-400 rpm diff. between lockup and non. it wont hurt anythig but your wallet in extra gas mileage. now I have a lock up stall conv. so Im making a switch. just flip the switch on when on the freeway and off when you get off the freeway.
chris
1986 Iroc Z
355, ported camel hump heads,750 holley, 700r4, 10.5 compr., forged flat tops, solidcam .501I .510E, 4gen rear w/3:73 posi, girdle, and disc's, Edel. torker II, shift kit, 3500 stal, hedmann LT. headers, 4 gen seats, man. strg., lt1 starter, alum. w/p, msd 6al, coil, dist., mallory wires.13.34 @102mph best w/that combo. have trick flow heads and tighter conv. to put in currently.
1995 z28,SS Hood, Iroc style spoiler, tints and black outs, 700r4,2400 act. stall speed,B&M hammer shifter, 17" budnick trilogy III wheels, 275/40 ZR17, 160 stat, man. cooling fan sw., homemaid CAI,1LE elbow, hypertech airfoil, t.b.bypass,!cat, flowmaster, !maf screen, relocated batt., 1LE front l.c.a.s', poly trans and torq.arm bushings, MSD 6AL, custom program, p&p maf, accel coil, and under drive pulley
mods that i have, just not on car yet:
msd wires, edelbrock mid. headers, edelbrock rpm catback
Old Aug 2, 2002 | 07:09 PM
jayman350's Avatar
Post
any idea which wire is the tcc wire on that cluster? (color wise)
I've been without a lockup for a long time but I know that I should probably rig up a switch to save myself some $$ in gas
I've also heard that locking up the TC in 3rd is good for almost .10 in the 1/4, thats coming from a TTA guy so it might have something to do w/ the turbo but I'm not sure
Jay
black 85 Z28 - waiting on a new paint job, then she'll be real purty
87 Chevy S10 Blazer- 2.8 liters of pure fury
Jay's Website
yahoo im: wildcat856
AIM: Jayman85Z
Homer no function beer well without
check out GMPerformance.org
Aaront810
Aug 29, 2020 09:34 PM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
Daluchman1974
Sep 11, 2015 06:12 AM
z28cam1993
Sep 9, 2015 04:08 AM
