gm fastburn heads?
Old Aug 18, 2002 | 06:44 PM
crazyk1le's Avatar
Post gm fastburn heads?
what do you guys think of the gm fast burn heads, and the vortec tpi base is it a stock intake or does it have bigger runners or more material to port?
Old Aug 18, 2002 | 07:05 PM
jms's Avatar
jms
Post
The Scoggin-Dickey TPI intake for the Vortec (and also fits the FastBurns) is based on the Edelbrock TPI intake.
The ports (at the runners) on mine measured almost 1-5/8" before porting (stock is a little less than 1-1/2"). There is plenty of meat left that could be opened up (I opened mine up to 1-3/4" to match my AS&M runners).
I had the most work at the injector nozzle area where they protruded quite a bit into the ports since the Vortec/FastBurns use a taller port but the injectors are at the stock location.
jms
Old Aug 19, 2002 | 01:14 PM
OrangeIROC's Avatar
Wink
<font face="Verdana, Arial" size="2">Originally posted by crazyk1le:
what do you guys think of the gm fast burn heads, and the vortec tpi base is it a stock intake or does it have bigger runners or more material to port?</font>
GM Fastburn heads are sweet, they flow awesome numbers, i mean there are alot better flowing heads but if u looking for a good set of heads that arn't gonna dig a well in ur pocket then these heads are awesome.. vortec tpi base is aftermarket, i believe it is slightly bigger than stock, i could be wrong on this though, maybe somebody else could give you a more definate answer about it.. Fastburn heads =
1988 Camaro Iroc-Z
Medium Orange Metallic
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
