Is my BBC a freak?
Old Aug 11, 2002 | 05:54 PM
Timberwolf's Avatar
Post Is my BBC a freak?
I can't find this casting number in ANY of the books or online. I se things that are close in number, but miles apart in application, so I can't even make assumptions from that.
My number is 14015449
I have found 14015443 which is a 4 bolt main MK IV block from 87-90 trucks or motorhomes, and 14015445 which is 78-90 2 or 4 bolt (no other info listed)
Anyone actually have ANYTHING that shows my casting number?
Old Aug 11, 2002 | 07:41 PM
Stephen 87 IROC's Avatar
Post
Does it really matter?
What's the suffix code stamped onto the pad in front of the passenger side head or on the pad behind the water pump? That will tell you more about a block than a simple casting number. Casting number are used over many years and in many models of vehicles.
Chances are it's just a 454 Mark IV block. What else do you need to know? The heads will be junk anyway but the shortblock is a good start to any buildup. If it's a tall beck block you can build a bigger engine.
How complete is it?
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.418
Best MPH on a time slip: 117.01
Best corrected ET: 11.051
Altitude corrected rear wheel HP: 468
Best 60 foot: 1.595
Member of the Calgary Drag Racing Association
Old Aug 11, 2002 | 08:03 PM
91RS5speed's Avatar
Post
Is it fast and loud? I cant think of anyting else u need
http://bitchincamaro.no-ip.com 91 RS Camaro 5-speed black w/t-tops 305 TBI now TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
Old Aug 11, 2002 | 08:58 PM
Timberwolf's Avatar
Talking
Yeah it matters to me. I want to know as much about the block as I can, there are differences between castings and years and while it would have been fine to find out it's just a standard MK IV block, the fact that it seems to not be on ANY casting number list has me curious.
Not to mention, while planning a build up for this winter, I'd like to know wat I am starting with so I can begin accumulating parts while I'm still driving the car.
Yes it's fast, it's not super loud, but the Hooker headers and Flowmasters give it a nice rumble.
The heads I already know about, truck heads. Which probably means peanut ports. And that's how it acts. I can make earth crushing power up to about 5k rpm and it falls off hard. Burnouts are best accomplished in 2nd gear, as doing a 1st gear burnout puts you at the redline faster than you can shift the gears. But I have Merlin heads on teh way, so no worries there.
I can understand why it doesn't matter to many people, but to me, I like the research. I'd like to know ahead of time if it is a 2 or 4 bolt block without having to pull the pan. Since it is an odd number, I'd like to know if it has any other oddities I should plan around. Siamese bores? Bowtie Block? Boat Anchor? Tall deck? Short deck? Replacement block? Who knows?
The "desktop buildup" of the engine is one third of the fun
Anyone else have info that might be useful besides "who cares?"
[This message has been edited by Timberwolf (edited August 11, 2002).]
Old Aug 11, 2002 | 09:18 PM
Post
Get the suffix code off the block and forget about the casting number! Casting numbers mean very little.
Old Aug 11, 2002 | 09:38 PM
IROC5.7TPI's Avatar
Post
Sounds like a Mercruiser Marine block. Not positive, but in most cases marine applications have odd casting numbers.
Mike L.
1987 IROC Z 5.7 TPI A4 3.27 Borg-Warner four wheel disc
Mods:
2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified airbox w/ K&N's, Relocated MAT sensor, Gutted MAF, 160* thermostat, MSD 6A, Accel 8mm Wires, bypassed TB coolant, 3" Flowmaster 3 chamber single outlet, custom adjustable cutout, 3" MAC mandrel intermediate, airfoil, ported plenum. !smog, Crane AFPR, Accel rail mounted FP gauge, Harlan shiftlite, 24lb. injectors, Hedman headers, a few others I forgot...??? FINALLY GOT PAINT!!
Check out my IROC webpage!
Old Aug 11, 2002 | 09:44 PM
Timberwolf's Avatar
Post
Suffix is worn off, but the ID code is an oddity too. Usually they start with T and then have the rest of the numbers, including a partial vin. Mine starts with CGJ or CJG (don't remember) which is a known suffix, but not a prefix. Seems like when I looked it up as a suffix code it was a police block or something, been a while since I checked.
Old Aug 11, 2002 | 10:35 PM
ws6transam's Avatar
Post
Um, exactly what are you building these days, Timberwolf? I've been off the boards for a while ... In fact, I've turned into a downright hermit! If only I could figure a way to earn the $1300 I need for my cylinder heads....
Anyone got any used Edelbrock Victor 23 degree heads in 220cc intake volume, 70cc combustion chamber, 7/16 stud configuration? I need a set. I'm tired of seeing these wonderful car parts sitting around. I want to make them run!
http://camaroz28.cardomain.com/id/ws6transam
1984 Trans Am WS6/L69 305 H.O.
1.05 g sustained lateral acceleration verified!
14.039 at 100.82 MPH
NOT VAPORWARE! The Minirammed 385 shortblock is done.
Old Aug 13, 2002 | 08:10 PM
Timberwolf's Avatar
Post
Looks like the last casting number may be a 3 afterall. I did find this engine code on the ledge above the timing cover: T0912AKX
I had previously been looking on the ledge behind the alternator on the passenger side of the block to get those other numbers.
any help with the newly discovered code?
[This message has been edited by Timberwolf (edited August 13, 2002).]
Old Aug 13, 2002 | 08:52 PM
IROC5.7TPI's Avatar
Post
14015445...454.......78-90...2 or 4 bolt
That's the closest I could come up with....
Heres a link to other Chevy casting numbers...
http://www.mortec.com/bbc.htm
Mike L.
Mods:
Old Aug 14, 2002 | 12:10 AM
Post
T0912AKX
T = Tonawanda engine plant
09 = September
12 = Day of month
AKX = 1986 truck 454 CID. Originally rated at 240 HP. It had a manual transmission behind it. Engine is classified LE-8. The VIN code was W. It was in series 20 and 30 trucks. K20, K30 or C20, C30, etc. 3/4 or 1 ton pickup trucks.
See how much more info you can get from the suffix codes.
I think my block has the same casting number but came from an earlier truck. Mine is a 2 bolt main but having main studs installed then having it line honed makes it stronger than I'm going to need.
[This message has been edited by Stephen 87 IROC (edited August 14, 2002).]
Old Aug 14, 2002 | 01:43 AM
firechicken_3's Avatar
Post
stephen,
where did you get the info to decode, those numbers?
84' Firebird, 305ci lg4, 700R4, 288/292 duration .450/.460 lift,Edelbrock Performer intake, Holley 600cfm 4 barrel, K&N filter, Pacesetter Headers, 3'single exhuast, dual out muffler, no cat,Motive 3.73's and Auburn Posi
1/4mile 15.17sec @ 92.5mph
currently in pieces, for manual swap
Old Aug 14, 2002 | 07:33 PM
Post
Factory manuals
cmsmith
Sep 14, 2015 09:25 PM
buggy323
Jul 1, 2015 04:37 PM
Flint78
Jun 21, 2015 01:28 PM
ChrisFrez
Mar 22, 2015 09:12 AM
Caps94ZODG
9
Jul 26, 2002 03:36 PM
