New Engine Specs
Old Aug 6, 2002 | 11:45 AM
Teknohund's Avatar
Post New Engine Specs
Here are the 350 engine spec's on the engine I just bought. We (me and my dad) just dropped it off at the shop to get installed sometime this week along with the tranny rebuild.
4-bolt main block bored .030 over, decked .010
.010R and .010M cast crank
ARP rod bolts, rods resized
TRW forged flat-top pistons
MOLY rings
Michigan (sp?) bearings
LT-1 heads
Manely Valves 2.02-1.6
Hard ex seats
Z-28 valve springs
New pushrods
Elgin rollar tip rockers
Speed pro Hyd. Cam
302 degrees, 536 lift int, 536 lift Ex
Performer RPM intake
H. V. oil pump, steel rod. New pickup.
GM chrome valve covers and timing covers.
Everything new
Well, those are the specs, what do you all think?
Chris
'87 Camaro<br /> LG4, SLP 1 3/4" coated headers, !CAT, cutout, 3" Flowmaster single outlet, SFC's waiting to be installed...http://community.webshots.com/scripts/editPhotos.fcgi?action=showMyPhoto&albumID=3073201 8&photoID=30732123&security=AUYCDNfcRa
Old Aug 6, 2002 | 03:33 PM
jd13's Avatar
Post
Looks like it will be pretty nice. I don't really have a clue what kind of hp it should be pushing though. Keep us updated
Old Aug 6, 2002 | 04:18 PM
AutoRoc's Avatar
Exclamation
Ummm.Is it an LT1 block? I would hope so because you list LT1 heads...That cam sounds huge too! very cool Just make sure the heads are matched properly.
Denny Villemure
1989 Camaro IROC-Z Convertible, 305 TPI, 2.73 Gear, Flowmaster 2 chamber. 15.60 on motor, 14.20 on a 75 shot from NX. Woo hoo!
www.denny.cz28.com
Old Aug 6, 2002 | 10:39 PM
Chuck!'s Avatar
Post
I thought the Z28 spring was only good to about .500 lift? That's the spring Im runnin on a set of Vortecs
Did you do all the work to the LT1 heads to make them fit on the gen 1 block, or is it an LT1 block? I know I saw an article how to make the LT1 heads fit a normal block.
Old Aug 6, 2002 | 11:53 PM
Stephen 87 IROC's Avatar
Post
I also wonder about those springs. You should get the springs recommended for the cam. That's too much lift for a stock spring.
Carb size?
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.589
Best MPH on a time slip: 116
Best corrected ET: 11.079
Altitude corrected rear wheel HP: 468
Best 60 foot: 1.617
Member of the Calgary Drag Racing Association
Old Aug 7, 2002 | 10:40 AM
Teknohund's Avatar
Post
We decided on the other forum that the heads were early 70's model LT1's, so less modification is required. I was thinking about 700 or 750 edelbrock carb. The guy who built it said once fully tuned, the engine would be good for right around 400 HP
thanks
Chris
Old Aug 7, 2002 | 12:56 PM
RedIrocZ-28's Avatar
Post
Ohhhh the old LT1 heads. Ok, they should work.
The Z28 springs however I don't believe will work. You MUST have the machinist check the springs for coil bind numbers. 400 hp? Sounds very reasonable.
pimpss96
Feb 12, 2015 01:28 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
IDOXLR8
Aug 6, 2002 12:30 PM
jrp4uc
Jun 19, 2002 06:20 PM
