Timing on TPI
Old Aug 19, 2002 | 01:38 PM
FastFormula89's Avatar
Exclamation Timing on TPI
I was wondering what people set their timing at on TPI motors. I think I am losing power because my timing is set at 0! Any input would be great.
Donny
1989 Firebird Formula
Emmisions Legal
12.198@112.4
Old Aug 19, 2002 | 01:46 PM
irocz383's Avatar
Post
Your base timing from the factory should be set at something likt 6-8 degrees advanced!
If you want more advance its your call!
Old Aug 19, 2002 | 04:23 PM
91RS5speed's Avatar
Post
I run mine at 10
http://bitchincamaro.no-ip.com 91 RS Camaro 5-speed black w/t-tops 305 TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
Old Aug 19, 2002 | 05:36 PM
Irocvette355's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by 91RS5speed:
I run mine at 10
</font>
Yeah..what he said
1989 IROC-Z 355 M5
13.0@104
MACC All Camaro Show-
1st Place
3rd Gen Modified
1988 Chevrolet K-5 Blazer
6000 lbs. of a real SUV
2001 Yamaha Raptor
92 mph on radar!
Old Aug 19, 2002 | 06:26 PM
Damon's Avatar
Post
Ditto. Bump to 10* is a no-brainer on pump 92 octane with a stock chip. I've seen others go as high as 14*, but they were unique situations and couldn't apply to every car.
capebuf
Jan 13, 2015 07:22 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
4586
Dec 6, 2014 05:20 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
