When is descreening your MAF a good idea?
Old Aug 3, 2002 | 11:19 PM
Kodiak2727's Avatar
Question When is descreening your MAF a good idea?
I have a 88 GTA with the 305 TPI, i have an SLP CAI with the stock throttle body, would descreening my MAF be a good idea or a bad one? Thanks
Old Aug 4, 2002 | 03:32 AM
AutoRoc's Avatar
Exclamation
It's a good idea to do it just before you are expecting your best track times If you are worried about the wire element being injured with debris, just remove the screen behind the wire. One screen flows a lot bettr than 2 screens! I used Needle-nosed pliers myself. goodluck
Old Aug 4, 2002 | 07:06 AM
87DJP2001's Avatar
Thumbs down
NEVER a good idea to descreen your MAF. A Third Generation Car MYTH. Or if you want to learn the hard way "Do it" and pay for a new one when a Code 33 keeps showing up.
Old Aug 4, 2002 | 10:47 AM
Z28ROC's Avatar
Post
I can't see how removing the rear screen would cause a problem. But I would leave the front one alone.
Mario,
White 94 Z28
Yeah I got a few mods
Video
Black 87 IROC-Z
Old Aug 4, 2002 | 11:08 AM
aklim's Avatar
Post
A qoute from LPE
http://www.lingenfelter.com/lingenfe...=17&pf%5Fid=77
Old Aug 4, 2002 | 12:22 PM
87DJP2001's Avatar
Thumbs down
Yea! They will screw one up and charge you $400 for it. Run out and buy it now,.100 of second. Ha. Buy a Wells Maf and get better performance without touching it for $170 new.
Old Aug 4, 2002 | 12:56 PM
irocbob89's Avatar
Post
I did it on both of my irocs, i never had any problems. Just be careful and not hit anything inside the maf and you will have nothing to worry about.
Old Aug 4, 2002 | 01:15 PM
Sciguyjim's Avatar
Thumbs down
It can help you but there are possible problems. Here are a couple articles that explain the pros and cons:
http://www.gmtips.com/3rd-degree/dox...maf-screen.htm
http://www.thirdgen.org/techbb2/show...hreadid=117164
Old Aug 4, 2002 | 07:06 PM
IROC5.7TPI's Avatar
Post
My $.02-
I've personally de-screened both sides of the MAF on my car as well as about 4 or 5 other cars and not one of them seen any adverese affects.
One of the problems, especially on Firebirds is that the screens in the MAF straighten out the airflow after a bend in the inlet track. The firebirds have the bend right before the MAF, so the it does create a turbulence problem.
On the Camaros and Vettes there are no bends to worry about so I don;t ever have any problems.
Mike L.
1987 IROC Z 5.7 TPI A4 3.27 Borg-Warner four wheel disc
Mods:
2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified airbox w/ K&N's, Relocated MAT sensor, Gutted MAF, 160* thermostat, MSD 6A, Accel 8mm Wires, bypassed TB coolant, 3" Flowmaster 3 chamber single outlet, custom adjustable cutout, 3" MAC mandrel intermediate, airfoil, ported plenum. !smog, Crane AFPR, Accel rail mounted FP gauge, Harlan shiftlite, 24lb. injectors, Hedman headers, a few others I forgot...??? FINALLY GOT PAINT!!
Check out my IROC webpage!
DirtyDaveW
Dec 1, 2016 05:37 PM
SmokinZ28lt1
Feb 5, 2015 04:33 AM
89 iroc zl1
Jan 14, 2015 02:18 AM
Dec 23, 2014 07:52 AM
Skull Leader
Aug 10, 2002 11:01 AM
