what's the trick to seating the tranny pump?
Old Aug 24, 2002 | 04:21 PM
john-e-boy's Avatar
Post what's the trick to seating the tranny pump?
I am finishing up my tranny rebuild on a 700R4 and I am trying to install the pump but it doesn't seem to want to seat itself. It goes down to the seal and stops, Is there a trick to getting the pump to sit right??
John
Old Aug 25, 2002 | 09:07 AM
GMTech's Avatar
Post
The two teflon seals on the bottom of the stator support are getting hung up on the Reverse Input Housing. Get some vasoline or TransJel to temporarily "glue" them in place while you slide it down. If you force it, you will damage the teflon seals and burn up the revese clutches.
Webmaster:SETHIRDGEN
GM Tech
ASE Master Auto Technician + L1
1987 Trans Am: 357ci
Ported TFS heads, ZZ4 cam, headers & exhuast and other go fast goodies
13.53 @ 103.77
BinkZ28
Apr 20, 2015 09:10 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Snoman73
Nov 17, 2014 07:22 PM
Timberwolf
Jul 30, 2002 08:31 PM
